Thread: Is this safe, or retarded |
Silver Member Username: Legacyaudio
Post Number: 190 Registered: Feb-05
| Posted on Friday, March 23, 2007 - 01:26 pm: |
using a brass bolt from local hardware store for my battery post because the stock one is too short |
Gold Member Username: Naledge503
Http://com4.runboard.c...
Post Number: 1192 Registered: Jun-06
| Posted on Friday, March 23, 2007 - 02:07 pm: |
You can actually buy longer posts. I had to get one for my old bravada. Google "gm side posts". I pretty sure thats what your talking about and will need. |
Bronze Member Username: Mash4kash
Lafayette,
LA
Post Number: 64 Registered: Feb-06
| Posted on Friday, March 23, 2007 - 02:16 pm: |
they have bolts in bolts at o'reilly and autozone the bigger bolt is same as stock goes in to the battery after you tighten it theres a smaller bolt thats screwed in the top of the bigger bolt which can be used for other + and - lugs. |
Lafayette,
LA
Post Number: 65 Registered: Feb-06
| Posted on Friday, March 23, 2007 - 02:17 pm: |
I meant side post bolt in bolt |
