Home > Message Board > Car Audio > Amplifiers > Archive through April 02, 2007 > Kenwood amp problems
Author Thread: Kenwood amp problems
Username: Dlugi02
I recently installed a Kenwood amp rms at 4 ohms is 300 watts. Pushing a xplod at rms 325 at 4 ohms. The amp cuts off at high volumes and turns back on when volume is turned down. The amp turns completely off. There's only one light on the amp and it goes off. I tried using a different amp and still had the same problems. The amp is hooked up with a high input not rca's. PLEASE HELP!
Username: Chaunb3400
Huntsville, Alabama
U.S.
Post Number: 11897
have u tried using rca's??
Username: Dlugi02
Yes the amp still cuts out.
Username: Kaprese
Walstonburg, NC
Post Number: 37
Thats nothing new to me I had a Kenwood KAC-8101D amp rated 200rms at 4ohms and 400rms at 2 ohms and my amp would keep cutting off but then I bought a fan and it never cut off again I think those class D amps from kenwood get hot fast
Username: Shade
Moxee, Wa
U.S.
Post Number: 143
yah kenwood is crap, i had a 7202 runing my type r comps and it was cutting out after like 20mins of play
Username: Oneracistguy
TWO EGG, FL
Post Number: 485
try turning ur preout voltage down on ur amp
but u really need a new setup xplodes and kenwood isnt no good
Username: Lbeckner
Tulsa, Ok
Usa
Post Number: 1468
also check your power wire and ground and make sure they are good.
Username: Mike_16
Burlington, Wisconsin
Us
Post Number: 405
haha i had a kenwood 9102d and it never gto hott on me even after 2 1/2 hours of play but i did recently have it blo won me but i think cuz it got wet, but yea i wil never buy one again the sound is deep but not so clear, but yea i dont like em
Username: Dlugi02
It was the ground. Thanks to everyone.
Username: Imalik
SD2.5, New Jersey
Ocean
Post Number: 170
Try the amp with different subs, the problem may be the speakers
Username: Beatitdown
the problem would never be the speakers. the speakers perform because of the amp, not the other way around.by the way.sony sucks. return them and get a better sub trust me
Home > Message Board > Car Audio > Amplifiers > Archive through April 02, 2007 > Kenwood amp problems [ « Previous ] [ Next » ]
