Home > Message Board > Car Audio > Amplifiers > Archive through April 02, 2007 > BOSS amps?
Author Thread: BOSS amps?
Username: Bigman3889
Post Number: 67
Hows a boss amp??
BOSS GT880
and the Boss BLX4000
Username: Adam_s
15 TC9 Hybrid, RE MT Softparts
Post Number: 888
Boss is very very low grade. Wouldn't recommend anything made by them.
Username: N2audio
Lawrence, Ks
Post Number: 1242
typical over-rated budget amps, but if you like the price I'm sure they'd work ok if you don't abuse them.
Keep in mind you won't get near rated power out of them. Especially the 880. It's rated for 150x4 at 4 ohms -- no way.
With 2x25A fuses there's no way it's going to produce much more than 500w, 600 tops.
So that would indicate 150x4 at TWO ohm stereo (300x2 bridged), and probably more like 100x4 at 4 ohms stereo.
All things considered, a good amount of power for a <$150 amp.
The big question is - will it last?
The blx4000 is a low impedance amp. I can't help but wonder if a cheap amp like that can withstand that level of stress.
Username: Renegadesrun
Lafayette, IN
US
Post Number: 609
Paperweight. Doorstop. Car wheel chock. Boat anchor. All ways these amps can be used for long periods of time and have them fuction 100%
Car audio is not one.
Username: Pete_the_pup
Gaffney, Sc
Usa
Post Number: 23
I'm no expert, but I have a Boss Ripper 565 1000w peak that I've had for 4 years. It's a little rusty in places but it works just as good now as it did when i bought it. PtP
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 4297
BLX should put plenty power, but boss is thrash. Good budget stuff, only.
Username: Moey_g
Sydney
Australia
Post Number: 83
I went through 5 boss amps when i was a noob. Take it from someone with experience, dont buy them...
Home > Message Board > Car Audio > Amplifiers > Archive through April 02, 2007 > BOSS amps? [ « Previous ] [ Next » ]
