Home > Message Board > Car Audio > Amplifiers > Archive through March 23, 2007 > How to hook up speakers without rca j...
Author Thread: How to hook up speakers without rca jacks
Username: Big_fletch
Newport, Ar, Ar
United states
Post Number: 648
ok my friend has a 2005 f-150 and hes got stock cd player and on the back it dont have no rca outlets and i think there is a way to splice the speaker wire in the back of the vehical and just cut the slice the rca cables and just run them on the speaker wire connected to the factory speaker please help i know there's a way just cant remember
Username: Nd4spd18
Southeast PA
Post Number: 1038
You're thinking of a line out converter.....
Newport, Ar, Ar
United states
Post Number: 650
how much do they cost and how do i wire it up then
Username: Riskyb
Post Number: 504
They cost like 30$ at best buy but you can buy them for like 10$ on the net. All you do basically is twist the speaker wires for your rear speakers to the wires on the converter.
Home > Message Board > Car Audio > Amplifiers > Archive through March 23, 2007 > How to hook up speakers without rca j... [ « Previous ] [ Next » ]
