Thread: Will this sub work with this amp? |
New member Username: Sexybrenty
Post Number: 6 Registered: Mar-07
| Posted on Wednesday, March 21, 2007 - 07:08 pm: |
so doing some research on some ohm stuff i have no idea about, i found out my rockford fosgate 450.2 amp has this: RMS Power Output: 4 Ohms: 100 watts x 2 chan. 2 Ohms: 225 watts x 2 chan. 4 Ohms Bridged: 450 watts x 1 chan. And my sub is a pioneer and it has 800 watt max power with 4 ohms, does this mean my sub is too powerful for my amp |
Silver Member Username: Goodie_goop
Midland,
Texas
U.S.
Post Number: 437 Registered: Oct-06
| Posted on Wednesday, March 21, 2007 - 07:14 pm: |
whats the rms of the sub...max means nothing |
Gold Member Username: 420alldaylong
Post Number: 1120 Registered: Sep-06
| Posted on Thursday, March 22, 2007 - 12:42 am: |
Whats the ohm of the sub? |
Post Number: 7 Registered: Mar-07
| Posted on Thursday, March 22, 2007 - 01:07 am: |
ohm:4 rms: 150 w http://www.bestbuy.com/site/olspage.jsp?skuId=7675973&type=product&productCatego ryId=cat03081&id=1134702499042 Thanks for the help guys |
Post Number: 1125 Registered: Sep-06
| Posted on Thursday, March 22, 2007 - 01:46 am: |
4 Ohms Bridged: 450 watts x 1 chan for that sub. http://www.cardomain.com/shop/wooferwizard.pl?num_of_subs=1&impedance_of_subs=4o hm_svc&x=158&y=15 |
Post Number: 9 Registered: Mar-07
| Posted on Thursday, March 22, 2007 - 01:50 am: |
thank joey for the help, but does that mean my sub will work and it wont hurt the amp at all? |
Silver Member Username: Adam_s
15 TC9 Hybrid,
RE MT Softparts
Post Number: 882 Registered: Aug-04
| Posted on Thursday, March 22, 2007 - 11:13 am: |
That sub will be overpowered and most likely blow. |
Silver Member Username: Killswitchjd
Post Number: 337 Registered: Apr-06
| Posted on Thursday, March 22, 2007 - 05:45 pm: |
you can just hook it up to the first channel and NOT BRIDGE THE AMP. If you bridge the amp it will almost surely blow. are you sure the max is 800 and the rms is 150? marketing gimmicks, eh... usually the rms is at least near half the max..... |
Post Number: 10 Registered: Mar-07
| Posted on Thursday, March 22, 2007 - 08:30 pm: |
ok guys thanks for your help a lot, but what do u guys think would be the best recomended sub for my car then?its a dakota with a extended cab and id prefer to have one twelve, thanks guys |
Bronze Member Username: Sexybrenty
Post Number: 12 Registered: Mar-07
| Posted on Thursday, March 22, 2007 - 11:54 pm: |
im confused about this rms thing, because if the rms on the amp is 450 while the sub is only 150, why wouldnt it work? im a total newb at this and am still rather ocnfused about this whole thing. |
Silver Member Username: Oleg
Santa Monica,
CA
Post Number: 661 Registered: Nov-04
| Posted on Friday, March 23, 2007 - 02:06 am: |
Don't bridge the amp, but rather use only 1 channel for the sub - should be ok I suppose. If you do bridge it, turn the gain way down - although that isn't best. |
