Home > Message Board > Car Audio > Amplifiers > Archive through March 23, 2007 > Ohms question
Author Thread: Ohms question
Username: Riggins
I am new to this and would like to put a systemin my suv. i am looking at 2 subs--12" with a 1200 watt each and 4 ohms. what does this mean and what kind of amp do i need?
Username: Mash4kash
Lafayette, LA
Post Number: 52
single voice coil or dual voice coil subs?
Username: Riggins
dual.
Username: Mash4kash
Lafayette, LA
Post Number: 54
if they're svc you gonna need a 2 ohm amp if they're dvc you go need a 1ohm amp are those subs 1200 watts rms or peak whats the rms on those subs
Username: Riggins
1200 peak. what is the general rule for ohms?
Username: Hockeyknight
Post Number: 978
ohms have to do with how you wire ur subs.....and u never use peak always rms...what subs are they??
Username: Riggins
Pyle PL1290BL 12. or Cerwin Vega V MAX 122. 600 RMS, 1200 (RMS pair), 1200 max, 2400 (max pair); 1 ohm/4ohm.
Username: Riggins
with the cerwin vega do i look for an amp that an handle 600 or 1200 rms.
Username: Carguy
Post Number: 6029
Don't get Pyle, they're low in quality chart.
If the CV's are really 600w rms, then you need 1200w rms amp to power both. Since you mentioned 4ohms DVC subs, that means the amp has to put out 1200w rms @ 4ohms or 1ohm. Therefore, look for am that has those numbers.
Username: Riggins
So i got the CVs. they say they are 600w rms each (1200w rms pair) and can be wired at 1 or 4 ohm. Will this amp work before this buy it?
Memphis 16-PRD500.1 500x1 1OHM RMS
RMS Power (W) 200X1 @ 4ohms / 300x1 @ 2ohms / 500x1 @ 1ohm
THD @ 4 ohms 0.05%
Frequency Response +/- 0.5dB 10Hz - 500Hz
Username: 2pacalypse1971
Sandusky, Oh
Post Number: 261
if they are 600 rms each and you get that amp, you will only be fully powering one of the subs with 500x1 at 1 ohm, look at teh memphis 1000d or whatever the name of it is if your lookin at memphis specifiacally
Username: Mash4kash
Lafayette, LA
Post Number: 55
Or you could just get a hifonics 1606d which everyone says is 1200w rms @ 1 ohm give or take
Home > Message Board > Car Audio > Amplifiers > Archive through March 23, 2007 > Ohms question [ « Previous ] [ Next » ]
