Thread: Need power for my type x 12 |
New member Username: Russ636
Post Number: 1 Registered: Mar-07
| Posted on Wednesday, March 21, 2007 - 08:14 am: |
I recently purchased an Alpine type x 12 and an Alpine mrd1005 amp. I an very disappointed. I have 8s that hit harder. The stereo shop tells me I need more power. The amp is ran at two ohms and the certificate syas it is pushing 1176 watts. Why does it sound so weak. How much power do I need to push this sub? Its in a good box and was professionally installed. Any suggestions on the right amp to push this sub? |
Gold Member Username: 420alldaylong
Post Number: 1119 Registered: Sep-06
| Posted on Thursday, March 22, 2007 - 12:31 am: |
R GOFF Thats a good match. Sounds like you have your sub wired wrong. For you to get that amp down to 2ohm you need a dual 4ohm sub and this is how you would wire it. http://www.cardomain.com/shop/wooferwizard.pl?num_of_subs=1&impedance_of_subs=4o hm_dvc&x=137&y=15 |
Platinum Member Username: Chaunb3400
Huntsville,
Alabama
U.S.
Post Number: 11864 Registered: Jul-05
| Posted on Thursday, March 22, 2007 - 01:31 am: |
the type x is not a heavyweight when it comes to spl...check all of ur knobs make sure everything is set right..and Like joey said make sure it is weired right |
Post Number: 5 Registered: Mar-07
Both the sub and amp are wired correctly. The sub has dual 4 ohm voicecoils. The coil jumpers have it running at 2 ohm. It barely shakes my rearview. Should I be thinking about boxes instead? The box is a sealed .75 cubic ft box that is in the trunk of my G35. Will a larger box get me more bass? maybe ported? What amp will make this speaker pound? Alpine pdx1.1000? Fosgate power 2000bd1? I have a capacitor and dont want to alter my cars charging system. |
Post Number: 6 Registered: Mar-07
| Posted on Thursday, March 22, 2007 - 01:39 am: |
I would like to get spl without sacrificing sq. Do I need to off this speaker and try something else. JL W6? RF POWER? I am returning the amp and trying something else. |
Silver Member Username: Renegadesrun
Lafayette,
IN
US
Post Number: 604 Registered: Oct-04
| Posted on Thursday, March 22, 2007 - 01:40 am: |
Ported. |
Post Number: 1124 Registered: Sep-06
| Posted on Thursday, March 22, 2007 - 01:41 am: |
Thats a good amp a friend of mine is running one to a Kicker Solo Baric L7 15" and it hits pretty damn hard. Are you sure you have the sub wired right. |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 4298 Registered: Dec-05
| Posted on Thursday, March 22, 2007 - 02:57 pm: |
alpine Type X are power hungry, but they should flex something in your ride or is f*cked. If you want, sell it locally, buy a FI SSD and port it. |
Silver Member Username: Efil4zaggin
Chi Town,
IL
Cook
Post Number: 220 Registered: Dec-05
| Posted on Thursday, March 22, 2007 - 06:09 pm: |
ur amp does put out 1176 watts most likely @ 14.4 v, check your electrical system make sure ur charging voltage is around 14 v and make sure u r able to pump out around 80amps....(E*I=Watts) so if ur engine is running greater than idel speed u should be getting around 14v....take off ur capacitor and giv it a shot u'll porbably see a diffrence |
Bronze Member Username: Mschwitz
Milwaukee,
Wi
Post Number: 29 Registered: Sep-06
| Posted on Saturday, March 31, 2007 - 12:51 pm: |
Build a ported box around 3.0 to 3.5 ft 3 use 2-4" pnr ports and tune around 28-32hz. You will love this sub if you build the right box for it. I had to try four boxes last year and finally got it right. |
