Thread: Whats the best to worst brand amp out these 4 for solobaric 15's L7? |
Bronze Member Username: Mash4kash
Lafayette,
LA
Post Number: 34 Registered: Feb-06
| Posted on Tuesday, March 20, 2007 - 02:31 pm: |
Kicker, Soundstream, Rockford Fosgate, and Candence |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 4291 Registered: Dec-05
| Posted on Tuesday, March 20, 2007 - 02:41 pm: |
Kicker Rockford Cadence Soundstream Some guys will have differences.. but they're all good. What are you trying to push anyway? |
Post Number: 4292 Registered: Dec-05
| Posted on Tuesday, March 20, 2007 - 02:43 pm: |
oh sorry haha, if you're trying to push a solo baric L7 15" i'd go with kicker, just to match the setup. Is the sub DVC4 ohm o DVC2? |
Silver Member Username: Nd4spd18
Southeast PA
Post Number: 982 Registered: Jul-06
My order of preference: Cadence (Daytona series only) RF Kicker Soundstream Cadence (Daytona series only) are the most efficient amps out of those, and are good quality. RF and Kicker is really a tie, they are both great quality amps but will draw a lot of current. Newer SS amps are not that good ever since they were bought out by Power Acoustick. |
Lafayette,
LA
Post Number: 35 Registered: Feb-06
| Posted on Tuesday, March 20, 2007 - 02:44 pm: |
my 2 solobarics 5's L7 they're 2 ohm each man they sold the kicker 2500.1 fa 420 guess I'ma settle for 2 cadence M7000 for 370 |
Lafayette,
LA
Post Number: 36 Registered: Feb-06
| Posted on Tuesday, March 20, 2007 - 02:46 pm: |
Hey M.S. are 2 of these cadence amps good enuff for my 15 L7's? http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&sspagename=ADME%3AL%3ARTQ%3AUS%3A1 &viewitem=%26item%3D250094008523%26 |
Southeast PA
Post Number: 984 Registered: Jul-06
| Posted on Tuesday, March 20, 2007 - 02:49 pm: |
^^^^^^ Link don't work |
Lafayette,
LA
Post Number: 37 Registered: Feb-06
| Posted on Tuesday, March 20, 2007 - 02:51 pm: |
go to bay and put Item number: 250094008523 in the search box |
Lafayette,
LA
Post Number: 38 Registered: Feb-06
| Posted on Tuesday, March 20, 2007 - 03:02 pm: |
anyone know about the cadence Amadeus M7000 or the A7-HC? |
Southeast PA
Post Number: 985 Registered: Jul-06
| Posted on Tuesday, March 20, 2007 - 04:25 pm: |
With Cadence the Daytonas are the good ones, their other amps are not so great. Look into this amp: http://www.cadencestore.com/ProductCart/pc/viewPrd.asp?idcategory=97&idproduct=2 43 Or if you can't get that, I would get an RF or Kicker over either of the two amps you posted. |
Lafayette,
LA
Post Number: 39 Registered: Feb-06
| Posted on Tuesday, March 20, 2007 - 11:13 pm: |
how bout the hifonics BXi 1260D |
Gold Member Username: Nd4spd18
Southeast PA
Post Number: 1033 Registered: Jul-06
| Posted on Wednesday, March 21, 2007 - 12:02 am: |
Get the 1606d instead. That one's not really enough power. |
Lafayette,
LA
Post Number: 41 Registered: Feb-06
| Posted on Wednesday, March 21, 2007 - 12:14 am: |
a solobaric s15L7 takes 1000w rms 2000w peak i planned on getting 2 1206 since i have dual 2 ohm so i need a 1 ohm amp on each. Don't you think a 1606d is too much for 1 s15L7? Is hifonics better than cadence & soundstream or are they a tie with kicker ad RF? |
Lafayette,
LA
Post Number: 42 Registered: Feb-06
| Posted on Wednesday, March 21, 2007 - 12:26 am: |
Gold Member Username: Ctmike
Ct.
Post Number: 3667 Registered: Feb-06
| Posted on Wednesday, March 21, 2007 - 12:32 am: |
kicker and rf are alot better than hifonics. hifonics is good budget amp though. reason the 1606 was suggested is cause hifonics' overrates thier amps so you wont see 1600wrms, probably about 1200wrms give or take. also, you have an upgraded charging system yet cause looks like your going to need one. |
Lafayette,
LA
Post Number: 43 Registered: Feb-06
| Posted on Wednesday, March 21, 2007 - 12:50 am: |
ah i see damn ctmike we registered same time n u already gold n i ain't |
Bronze Member Username: Jeromebaker
Post Number: 93 Registered: Dec-05
| Posted on Wednesday, March 21, 2007 - 12:59 am: |
FOsgate Kicker Hifonics Never used soundstream or cadence so I can't say. The hifonics will be the cheapest and 98% of people can't tell the difference without seeing the amp. |
Lafayette,
LA
Post Number: 44 Registered: Feb-06
| Posted on Wednesday, March 21, 2007 - 01:06 am: |
I guess a KX2500.1 and ZX2500.1 the same right found a few KX2500.1 at 589 plus 38 shipping good deal or what? |
Lafayette,
LA
Post Number: 45 Registered: Feb-06
| Posted on Wednesday, March 21, 2007 - 01:10 am: |
guess I should go with kicker kx2500.1 on 2 S15L7's then? |
Ct.
Post Number: 3671 Registered: Feb-06
no, not the same. kickers' kx and sx series are 1ohm stable, the zx's are 2ohm stable. |
Lafayette,
LA
Post Number: 46 Registered: Feb-06
| Posted on Wednesday, March 21, 2007 - 01:16 am: |
the dude advertised the kx runs 2500 watts rms at 2 ohm mono the zx says the same thing. |
Silver Member Username: Jblanford
Post Number: 606 Registered: Oct-06
| Posted on Wednesday, March 21, 2007 - 01:51 am: |
S.L.A.B.= Slow Loud And Bangin  |
Lafayette,
LA
Post Number: 47 Registered: Feb-06
| Posted on Wednesday, March 21, 2007 - 02:04 pm: |
U tell em Slow Loud And Bangin |
Lafayette,
LA
Post Number: 50 Registered: Feb-06
| Posted on Wednesday, March 21, 2007 - 02:45 pm: |
Hifonics seem to advertise they draw less power than other class d amps and I do want a class d amp that draw less power and puts out more I think that kicker 2500 gon kill my shyt with just 0 gauge big 3 a 105 amp alternator a duralast gold which has over 900 cca. Will 2 Hifonics 1606d put out 1200w rms each give or take and won't mess up my alternator? Cuz I don't really wanna upgrade alt if music not gonna bang any harder with HO Alt. I can get me a 200a alt for $170 but still. I'm tight with my benjamins  |
Post Number: 94 Registered: Dec-05
| Posted on Wednesday, March 21, 2007 - 03:38 pm: |
Hifonics amps are good like that, there is a knob on the amp which you can set to draw 9v or 12v and go easy on the current drain. |
Post Number: 95 Registered: Dec-05
| Posted on Wednesday, March 21, 2007 - 03:43 pm: |
But basically you can't put out more than 1000 watts constantly without upgrading to a better charging system. |
Southeast PA
Post Number: 1036 Registered: Jul-06
| Posted on Wednesday, March 21, 2007 - 10:00 pm: |
" I do want a class d amp that draw less power and puts out more " Then go with a Cadence Daytona! They are one of the most efficient amplifiers available. |
Silver Member Username: Big_fletch
Newport, Ar,
Ar
United states
Post Number: 647 Registered: May-06
| Posted on Wednesday, March 21, 2007 - 10:04 pm: |
the best hifonics amp to get is the xx models all the others are overrated to me |
Lafayette,
LA
Post Number: 57 Registered: Feb-06
| Posted on Thursday, March 22, 2007 - 12:26 am: |
"But basically you can't put out more than 1000 watts constantly without upgrading to a better charging system" Lets say I hook it up on 105 amp alt it bangs then if i hook it up on a 200 amp alt you sayin its gonna bang 47-48% more than with the 105 amp alt jerome? Matta fact whats the most watts I'm gonna get out a 105 amp alt constantly |
Post Number: 4299 Registered: Dec-05
| Posted on Thursday, March 22, 2007 - 02:59 pm: |
1000w rms dimming like a disco bro. |
Lafayette,
LA
Post Number: 58 Registered: Feb-06
| Posted on Thursday, March 22, 2007 - 03:11 pm: |
damn thats go be embarassing. neway I took yall advice and bought a 200 amp alt. for $170 now about the battery i either go with a duralast thats 800 cca and 1000 ca or the optima yellow top D34/78. Yeah the duralast gold is stronger but its a conventional battery and I'm worried bout when I'm at the light sitting in traffic that I'll kill the duralast if i kill the optima i can kill it 350 times and recharge it 350 times not the duralast. So do I need 1 optima yellowtop or 1 dualast gold or hell 2 optima yellowtops which i already had but sold awhile back |
Gold Member Username: N2audio
Lawrence,
Ks
Post Number: 1244 Registered: Mar-04
| Posted on Thursday, March 22, 2007 - 04:13 pm: |
Slab, If the alt was the limiter of music power just about all of us with stock electrical systems would be killing our engines every time the bass hits. Fortunately we have monster current producing batteries under our hoods to pick up the slack. You can get a TON of power from a 600CCA battery. All you can ask of your alternator is to produce enough current to keep the battery charged. At 2000w that COULD be an issue, but it has a lot to do with your listening habits. If you listen at a reasonable volume most of the time and only blast it once in a while to stroke your ego it might run fine for a long time. If you're going to be blasting it non-stop with the amp on the verge of clipping I would think you'll be making quick work of that GM alt. |
Lafayette,
LA
Post Number: 63 Registered: Feb-06
| Posted on Thursday, March 22, 2007 - 04:37 pm: |
Ok I get it I'll blast it 2 or 3 times a week but i still need advice on what batteries and how many batteries and do i still need the ho alt if only blsting at 2000w 2 or 3 times a week? |
Lafayette,
LA
Post Number: 67 Registered: Feb-06
| Posted on Friday, March 23, 2007 - 02:42 pm: |
