Thread: Amp HELP!!! |
Bronze Member Username: Splsq
Chesterland ,
Ohio
Post Number: 48 Registered: Mar-07
| Posted on Tuesday, March 20, 2007 - 12:01 pm: |
Well i just ordered offline 2 12inch Solo Baric L5s and need a amp to push them i have 3 amps in mind 1. Power Acoustic:RMS= 440watts x 2 2. Hifonics: RMS= 300watts x 2 3. Crunch: RMS= 600watts x 2 the subs are rated 600 watts RMS but im on a budget of 165 and these are in the range which one should i get? |
Bronze Member Username: Kaprese
Walstonburg,
NC
Post Number: 15 Registered: Mar-07
| Posted on Tuesday, March 20, 2007 - 12:54 pm: |
Crunch amp because at least you are getting the rated rms the other amps are underpowering them a little but my second choice would be that Acoustic amp. |
Gold Member Username: Ctmike
Ct.
Post Number: 3641 Registered: Feb-06
| Posted on Tuesday, March 20, 2007 - 12:57 pm: |
my suggestion, save more. i wouldn't buy any of those amps, but if i had to i'd buy hifonics if i was on a tight budget. crunch amps used to be decent but from what i hear nowadays their crap. and why stuck on a 2 channel? |
Chesterland ,
Ohio
Post Number: 50 Registered: Mar-07
| Posted on Tuesday, March 20, 2007 - 01:57 pm: |
well here are the links to the amps i want to get and yea im on a tight budget(REAL TIGHT) Power Acoustic:http://www.hifisoundconnection.com/Shop/Control/Product/fp/vpid/2888188/vpcsid/0 /SFV/30046 Crunch:http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=16691 Hifonics:http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=16347 Tell me which one u think i should get for 2 12inch Solo Baric L5s(RMS=600 watts each) |
Ct.
Post Number: 3643 Registered: Feb-06
| Posted on Tuesday, March 20, 2007 - 02:14 pm: |
this amp would be the cheapest i'd go: http://cgi.ebay.com/06-HIFONICS-BXi1606D-CLASS-D-Mono-Amplifier-BRAND-NEW_W0QQit emZ140097413760QQcategoryZ18797QQrdZ1QQcmdZViewItem?hash=item140097413760 maybe you could find one cheaper if you look around, but that would be the lowest "budget" amp i'd ever get. and hifonics is a little overrated, so you'll see about 1200-1300wrms from that amp. but you also need to post the vc's of your subs (i know they come either dual 2 or 4ohm vc, but you really need to post that info for better help). |
Chesterland ,
Ohio
Post Number: 51 Registered: Mar-07
| Posted on Tuesday, March 20, 2007 - 02:24 pm: |
there 2ohm subs and i have like from 165-200 to spend like i said im on a tight budget and i got the subs on sale so alls i need is a amp that can push 600 watts each sub. |
Silver Member Username: Nd4spd18
Southeast PA
Post Number: 983 Registered: Jul-06
| Posted on Tuesday, March 20, 2007 - 02:47 pm: |
Definitely get the Hifonics Bxi amp that ctmike posted, it is better than the Zxi. Crunch and power acoustick absolutely suck. |
Chesterland ,
Ohio
Post Number: 52 Registered: Mar-07
| Posted on Tuesday, March 20, 2007 - 05:06 pm: |
well i no someone who has that same power acoustic amp on 2 12inch Kicker Solo Baric L7s and i cant breathe when im in his car. So i dont no it pushes 380 watts RMS when my L5s need 600 and the L7s have 750 and they pound really hard. |
