Home > Message Board > Car Audio > Amplifiers > Archive through March 23, 2007 > Wiring
Author Thread: Wiring
Username: Rdesabre
I hooked up all the cables properly and still no power to the amp??? could the rem being hooked to the wrong thing cause this?
Username: Van_man
Boston South, MA
Post Number: 2212
yes. You need a switched 12 volt source. Should be blue wire of hu. Or just find a wire thats hot when the key is turned on. Cig lighter? then stick it in the fuse panel with a fuse on it.
Home > Message Board > Car Audio > Amplifiers > Archive through March 23, 2007 > Wiring [ « Previous ] [ Next » ]
