Home > Message Board > Car Audio > Amplifiers > Archive through March 23, 2007 > Ala
Author Thread: Ala
Username: Mash4kash
Lafayette, LA
Post Number: 31
I have a 1995 Impala SS, factory alternator is 105 amps I have 1 kenwood amp on highs and mids with 1 30 fuse then I was gonna go with either a kicker 2500 or 2 cadence m7000 which are 1000w rms apiece can I just do the big 3 or must I upgrade to a 200 amp alternator to get full power? will i even get full power with more amps to spare wit a 200 amp alternator or do i need more than 200 amps? my subs will be 2 S15L7's in ported box at 38 Hz
Username: Chvss
La Mirada, California
U.S.A
Post Number: 18
Stop with the run ons!!!!!!!!
Username: Hockeyknight
Post Number: 966
HO Alt
Username: Mash4kash
Lafayette, LA
Post Number: 32
wha u talkin bout jose
Username: Nd4spd18
Southeast PA
Post Number: 971
You will definitely need an HO alt when running 2000w RMS.
200 amps is the smallest you would want to use when running that amount of power, but more is always better.
Username: Mash4kash
Lafayette, LA
Post Number: 33
1 my potnas said when he put a HO Alt the music didn't hit any harder just stopped the lights from dimming. Then I said whats the point of putting a HO Alt if its not gonna put more juice to subs and amp? Just get 1 optima yellow top and 0 gauge wires with 0 gauge big 3
Post Number: 970
if ur amp is drawing a lot of current and u dont have a beefed up electrical system ur voltage is gunna drop really low and u can harm ur amp
Home > Message Board > Car Audio > Amplifiers > Archive through March 23, 2007 > Ala [ « Previous ] [ Next » ]
