Home > Message Board > Car Audio > Amplifiers > Archive through March 23, 2007 > How to determine amp settings?
Author Thread: How to determine amp settings?
Username: Pitbullguy
Chicago, Illinois
I Eats Beats...
Post Number: 1068
Got my stuff installed this morning, i'm running 2 12" arsenals off an Elemental Designs nine.1
how do i determine where to leave all the settings??
LPF: 35hz-400hz
Sub Sonic Filter: 15hz-50hz
Bass Boost: 0db-18db
Gain: Minimum-Maximum
Phase: 0-180
If someone could explain or give me a link to some good info that'd be great, thanks!
Username: N2audio
Lawrence, Ks
Post Number: 1238
LPF is largely personal preference, but generally for subs it will be somewhere near 80hz
Sub sonic filter depends on the type of enclosure. If it's sealed you can either disable it, or set it very low (~15). If it's ported it should be set somewhere close to the tuning frequency of the enclosure.
Bass boost - as close to zero as possible -- if your gain is set correctly you shouldn't need it.
Gain -- you SHOULD learn to set it with a DMM, it isn't that difficult
Home > Message Board > Car Audio > Amplifiers > Archive through March 23, 2007 > How to determine amp settings? [ « Previous ] [ Next » ]
