Thread: U.S. amp 4000x competition amp |
Bronze Member Username: Turnmat
Post Number: 96 Registered: Feb-07
| Posted on Sunday, March 18, 2007 - 01:38 pm: |
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem%26item%3D170091691825&fromMakeTrac k=true Is this amp any good? |
Silver Member Username: Nd4spd18
Southeast PA
Post Number: 948 Registered: Jul-06
| Posted on Sunday, March 18, 2007 - 05:20 pm: |
US Amps are excellent quality. But you need a 16 volt electrical system for that one.... |
Post Number: 100 Registered: Feb-07
| Posted on Sunday, March 18, 2007 - 05:56 pm: |
I plan on getting a H/O alt and putting two Kinetik 2000's in the trunk.The alt is 200 amps think that would be enough |
Southeast PA
Post Number: 959 Registered: Jul-06
| Posted on Monday, March 19, 2007 - 12:51 am: |
Doesn't matter how many amps your electrical system is capable of, if it's not a 16 volt system you won't get the advertised power from that amp. Amps and volts are not the same thing, and one is not a substitute for the other. |
Silver Member Username: Turnmat
Post Number: 107 Registered: Feb-07
| Posted on Monday, March 19, 2007 - 01:00 am: |
gotcha thanks for your help |
Gold Member Username: 420alldaylong
Post Number: 1083 Registered: Sep-06
| Posted on Monday, March 19, 2007 - 01:10 am: |
Isn't that there entry level amp or no? |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 4288 Registered: Dec-05
| Posted on Monday, March 19, 2007 - 02:53 pm: |
i think that is their lowest line. Still good quality, but only puts 1200w rms. For the money, is good |
Silver Member Username: Renegadesrun
Lafayette,
IN
US
Post Number: 596 Registered: Oct-04
| Posted on Thursday, March 22, 2007 - 12:50 am: |
Nope,....and nope. That is an older US, which only had one line at the time (well kinda USA low ohm and US Xterminator high ohm) , and it was, and is, billy bada55. The X means it will make its most power at 4ohm. It should do 4k if fed well. I could never do so with one batt. 16v is not required, stable voltage is. Not a daily amp. Some do, but they run hotter than h3ll when pushed. Ive owned a couple. ;) http://www.soundsolutionsaudio.com/forum/index.php?showtopic=4693&st=0 The new Xterminator line is indeed the low line. That amp if def not it. Pay no more than 350 shipped. |
Lafayette,
IN
US
Post Number: 597 Registered: Oct-04
| Posted on Thursday, March 22, 2007 - 01:08 am: |
http://www.splbassx.com/forums/index.php?showtopic=145&st=45 |
Post Number: 108 Registered: Feb-07
| Posted on Thursday, March 22, 2007 - 02:00 am: |
thanks for the help Renegadesrun |
