Home > Message Board > Car Audio > Amplifiers > Archive through March 23, 2007 > What amp with Alpine Type r 12's?
Author Thread: What amp with Alpine Type r 12's?
Username: Nascarfan
Tallahassee, Florida
Hello, Im new here, I have a question that has prolly been asked a million times but here it is anyways, I have a 1999 Tahoe z71 and I just bought two 12" Type R's last night, and I need to find the right mono amp to power these, I currently have a new Alpine MRP-M850
Mono subwoofer amplifier. I dont believe this will be enough power to run both 12's can you guys give me some imput on a proper amp that will push these subs in a sealed or ported box.
Thanks Chris
Username: Ctmike
Ct.
Post Number: 3616
what are the vc of the subs? depending on that you'll want to look for an amp that'll do about 1200-1600wrms at the load you need.
Username: Nascarfan
They are dual voice coils
Username: Ctmike
Ct.
Post Number: 3619
well o.k., all type r's are dual vcs', but are they dual 4 or 2ohm vc? and budget for an amp?
Username: Nascarfan
Amp details
Details:
» mono subwoofer car amplifier
» 500 watts RMS x 1 at 4 ohms (800 watts RMS x 1 at 2 ohms)
» CEA-2006 compliant
» variable low-pass filter (50-200 Hz, 24 dB/octave)
» tuned Bass EQ (0-12 dB bass boost at 50 Hz)
» subsonic filter (24 dB at 15 Hz)
» MOSFET power supply
» STAR Topology (minimizes internal noise and prevents ground interference)
» gold-plated screw terminals
» speaker- and preamp-level inputs
» fuse rating: 25A x 3
Subwoofer details: Alpine Type R 1242D
SPECIFICATIONS
Power Handling
• Power Handling Capacity (Peak) : 1500W
• Power Handling Capacity (RMS) : 500W
General
• Diaphragm Material : Kevlar Reinforced Pulp
• Spider Material : Nomex
• Frequency Response : 23Hz - 500Hz
Username: Nascarfan
Amp details
Details:
SPECIFICATIONS
Power Handling
Dual Voice-Coil
Sensitivity: 87 dB
Speaker Configuration: Single Speaker
Peak Power Output: 1500 W
Diameter: 12 in
Cone Style: Cone
Cone Material: Kevlar Reinforced Pulp
Nominal Impedance: 4 ohm(s)
Nominal Input Power Rating: 500 W
RMS Power Output: 500 W
Overall Max Frequency Response: 500 Hz
Overall Min Frequency Response: 24 Hz
Maximum Input Power Rating: 1500 W
Username: Ctmike
Ct.
Post Number: 3620
look for an amp that'll do 1200-1600wrms @ 1ohm.
Username: Nascarfan
Can you throw a few name brands out there please
Username: Turnmat
Post Number: 91
if you stay with alpine...they have the pdx 1.1000 or the MRD-M1005.
Hifonics BXI1206D
but their are alot of other brands out their
Username: Nascarfan
Someone suggested that I might look into a 2 channel amp instead of a mono amp, oh by the way I just returned the Alpine MRP-M850 back to the store, seeing that this amp will not be sufficient to run both subs.
Username: Turnmat
Post Number: 94
the pdx 1.1000 will but out 1000 rms...and that is under rated...it will put out about 1100 watts rms. I actually have a pdx 1.1000 hooked upto two alpine type R subs. And man do they pound!!!
Username: Turnmat
Post Number: 95
oh and by the way it is two channels...
Username: Nascarfan
Post Number: 7
LOl I just looked on ebay and I think you are selling one of these with the subs right Matt?
Username: Turnmat
Post Number: 97
yea you got it...i am in the middle of re-doing my system
Username: Nascarfan
Post Number: 8
How about sending me mesage with a price including shipping to 32317, and I will buy it from you if the price is good.also do u have a box for those woofers?
Username: Turnmat
Post Number: 98
i do have the original boxes for the woofers...right now they are in a sealed box...
Just for the amp including shipping $374.00
Did you want both the amp+subs and the box for the subs?
make me a offer
Username: Nascarfan
Post Number: 9
Im on my way to work ill talk to you later about this ill be home about 6:30pm eastern time. I just bought the typr R subs last night, im interested in the box for your subs. send me pics to crashhawk1@yahoo.com. I have paypal verified and 99% feedback on ebay with 56 reporting.
Thanks Chris
Username: Sheriff
Post Number: 138
Matt, a pdx 1.1000 is a mono block amp.
Username: Sheriff
Post Number: 139
You should probably go with a Hifonics BXi 1606D
Username: Sheriff
Post Number: 140
Good Price from a good seller, no worries...
http://cgi.ebay.com/HIFONICS-BXI1606D-BRUTUS-BXI-1606D-CAR-AMP-NEW-2006_W0QQitem Z150101990588QQcategoryZ18797QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Username: Turnmat
Post Number: 99
its mono on the inside but has two speaker outputs
Username: 420alldaylong
Post Number: 1059
Christopher Tinter
Try this out
http://www.techronics.com/index.cfm?fuseaction=product.display&Product_ID=3942
Username: Hootz
Saskatoon, Saskatchewan
Post Number: 267
"the pdx 1.1000 will but out 1000 rms...and that is under rated...it will put out about 1100 watts rms. I actually have a pdx 1.1000 hooked upto two alpine type R subs. And man do they pound!!!"
He's got the dual 4 ohm subs, and that's not a 1ohm stable amp.
Username: Turnmat
Post Number: 101
it is a two channel amp...look at the pics. it has two channels and it will put out about 1100 watts rms at both four ohm and at two ohm
http://www.crutchfield.com/S-iNCiQPanKDV/cgi-bin/ProdView.asp?g=120&tab=morephot os&pi=1&i=500PDX1100&display=L#Tab follow that link..it shows two channels on the amp
With my setup i have each sub wired to each channel and it pushes them just fine
Username: Nascarfan
Post Number: 10
Im back home from work now, ok theres some good imput here, I will prolly run both subs @ 2 ohm because finding a amp that runs stable at 1 ohm is difficult to find, the subs normally are dual voice at 4 ohm. Im trying to get the most out of these subs with out frying an amp. So is a 2 channel amp out of the question?, and I guess what i need is to find a amp that will run
1000-1500 rms per sub.
Thanks
Username: Turnmat
Post Number: 102
that is alot of power to put to each sub...with that much power it is alot easier to blow your speakers...for that kinda power i would say Hifonics... just my opinion
Username: Sheriff
Post Number: 146
You should go with the Hifonics BXi1606D
1100 watts rms x1ch @ 2 ohms
Username: Turnmat
Post Number: 103
i would agree with Corey on this one...the most i would do is the Hifonics Bxi2006d 1300 watts rms @ 2 ohms
Username: Nascarfan
Post Number: 11
Is that per sub or does that get broken down to 500 rms after you bridge to 2 ohms? Im still learning the lingo here sorry..
Username: Turnmat
Post Number: 104
What Corey and me described is only one channel...so that would be for only one sub...but both of those amps go down to 1 ohm. so you could wire your subs to get the max out of either of those amps.
The amp Corey said about will put out 1600watts rms @ 1 ohm...800 for each speaker
The amp i described will put out 2000 watts rms @ 1 ohm...1000 watts for each speaker
Username: Nascarfan
Post Number: 12
If the information is correct below from crutchfield, then the actual rms to 2 subs @ 2 ohm would be 500 rms per sub
Details:
» mono subwoofer amplifier
» 1,000 watts RMS x 1 at 4 ohms
(1,000 watts RMS x 1 at 2 ohms)
Username: Nascarfan
Post Number: 13
I guess running at 2ohm it would be cooler on the amp instead of running it at 1 ohm each, is either one of those amps you mentioned run stable at 1 ohm?
Username: Nascarfan
Post Number: 14
How would this amp do? is it any good?
http://cgi.ebay.com/HIFONICS-BRUTUS-BXi2006D-MONO-D-2000W-AMPLIFIER-06-NEW_W0QQi temZ250095803648QQcategoryZ18797QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Username: Turnmat
Post Number: 105
the amps that we mention earlier will run at 1 ohm.
And the link that you have is actually the amp i was recommending...that amp will do exactly what you want it to
Username: Rovin
My 1 12 Atom...
Post Number: 10989
long thread
but simply
if u have 2 dual 4ohms subs then get a good amp that does about 1200wrms @ 1 ohm
if ur subs r dual 2 then 1200wrms @ 2ohms
those type Rs will handle 600 each comfortably
though u can use a 2 chan amp - a monoblock is prefered for subs ....
Username: Shade
Moxee, Wa
U.S.
Post Number: 137
just get a hifonics bxi2006d, u will be happy u did.
Username: Hootz
Post Number: 268
"it is a two channel amp...look at the pics. it has two channels and it will put out about 1100 watts rms at both four ohm and at two ohm
http://www.crutchfield.com/S-iNCiQPanKDV/cgi-bin/ProdView.asp?g=120&tab=morephot os&pi=1&i=500PDX1100&display=L#Tab follow that link..it shows two channels on the amp"
That's not a 2 channel amp, nor is it a 2000 watt amp. It's 1000W. And it's not a 1 ohm stable amp. It'd still work for him because it'll still do 1000 watts at 4 ohms, but if you wired that thing at 1 ohm you're just gonna burn it up. And having 2 speaker outputs doesn't make it a 2 channel amp. It says right on it that it's a mono amp, the two outputs would just be parallel connections. And even if it was a 2 channel, you'd bridge it anyways with subs. Unless you were a dufus and ran your subs in stereo
Username: Tc_skier
Post Number: 140
how bout an elemental designs nine.1?
Username: Nascarfan
Post Number: 15
Man im getting some good ideas here, thanks to you guys, its been a long time since I was into car stereos actually its been since 1985 since I had my last stereo competition, I placed 1st in the loudness category hitting 148.1db in a 1982 camaro, but that was along time ago! things have changed so much in design and competition, Im married now for 16 years and 3 kids later, and I have found new love again for my stereo (I know that sounds silly for a 42 year old), but, this is just another way to keep holding on to my youth..lol.
Thanks again everyone for the superb advice !!!
Username: Djbeanpole
Naptown, Indiana
Post Number: 349
I have those subs hooked up to a Kicker KX1200.1 1ohm stable bumpin.
Home > Message Board > Car Audio > Amplifiers > Archive through March 23, 2007 > What amp with Alpine Type r 12's? [ « Previous ] [ Next » ]
