Thread: How can I lower OHM load? |
New member Username: Montanapanama
Post Number: 1 Registered: Mar-07
| Posted on Sunday, March 18, 2007 - 09:55 am: |
I recently bought a set of 8 OHM JL W1V2s. I have an old (1992) Hifonics Ulysses running them (1 Ohm stable). Sounds ok, but the Amp only produces 100 watts at 4 Ohm with speakers in Parallel. Question: How can I get the system to a 2 Ohm load? Would adding a resistor work? Would this increase output? Thanks |
Silver Member Username: Imalik
Jackson,
New Jersey
Ocean
Post Number: 154 Registered: May-06
| Posted on Sunday, March 18, 2007 - 01:50 pm: |
This will help you out http://www.rockfordfosgate.com/rftech/woofer_wizard.asp?submitted=true&woofer_qt y=2&woofer_imp=2 |
Silver Member Username: Oleg
Santa Monica,
CA
Post Number: 652 Registered: Nov-04
| Posted on Sunday, March 18, 2007 - 02:32 pm: |
are those subs dual coil or single coil? |
Bronze Member Username: Jeromebaker
Post Number: 90 Registered: Dec-05
| Posted on Sunday, March 18, 2007 - 03:04 pm: |
I think you'd have to add more subs to lower the impedance below 4 ohms. I had a pair of JL 10w0's, they were SVC's, 4 ohm I believe, and I couldn't get them down past 2 ohms. That Hifonics is a good amp tho. |
Silver Member Username: Nd4spd18
Southeast PA
Post Number: 947 Registered: Jul-06
| Posted on Sunday, March 18, 2007 - 05:16 pm: |
You cannot wire two 8 ohm speakers to 2 ohms. Wiring in parallel to 4 ohms is the lowest you can get. |
Gold Member Username: Shortysetnies
Rock Vegas,
NC
US
Post Number: 1160 Registered: Mar-06
| Posted on Monday, March 19, 2007 - 12:34 am: |
http://www.j designs.info/phpBB2/viewtopic.php?t=107&highlight=adding+resistor thats what we decided on j designs (take the space out in j designs when putting the URL in. check that out though |
