Home > Message Board > Car Audio > Amplifiers > Archive through March 23, 2007 > 2xcerwin vega... which amp???
Author Thread: 2xcerwin vega... which amp???
Username: Mattyj33
Liverpool
UK
I have 2 x Cerwin Vega 124 rated at 400RMS each (800 Peak) and need an amp to power them. I was thinking the Cerwin Vega EXL 1000D. Is this to powerfull for the speakers seeing how the rating is 1 x 1000 @ 2ohms? If so what would you recommend?
Thanks
Username: Jeromebaker
Post Number: 88
MAn I haven't seen any CV's in like 10 years.
Damn good subs, even the ones they made out of paper. I don't know about their amps.
Username: Sheriff
Post Number: 143
Kicker 06ZX850.2 if you have the money.
Username: 420alldaylong
Post Number: 1061
Matthew Jones
How much do you want to spend on a amp?
Username: Mattyj33
Liverpool
UK
Post Number: 7
I am looking to spend about £200($300). I had a look at the kicker amp. How would i wire it up to my head unit which has 3 pre outs, 2 going to my 4 channel amp and 1 spare, the sub out. Would i connect the sub out to the amp and still bridge it?
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 4285
i heard their amps are good. Try them if you want man. If you need 1k at 2 ohms, buy kicker zx 750.1 if you're not sure.
Username: Mattyj33
Liverpool
UK
Post Number: 8
so basically anything with around 800wrms at 2ohms and a lower feq will do the job?
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 4294
basically yeah if they're DVC 2 ohm.
If they're DVC 4 ohm then look for 800w rms at 1 ohm
Home > Message Board > Car Audio > Amplifiers > Archive through March 23, 2007 > 2xcerwin vega... which amp??? [ « Previous ] [ Next » ]
