Thread: Amp help |
New member Username: Sayno2fathoes
Post Number: 1 Registered: Mar-07
| Posted on Sunday, March 18, 2007 - 12:46 am: |
i have one 15" kicker solo baric L7. what would be a good amp for it? |
Gold Member Username: Ctmike
Ct.
Post Number: 3615 Registered: Feb-06
| Posted on Sunday, March 18, 2007 - 12:48 am: |
budget and vc's of sub? |
Gold Member Username: 420alldaylong
Post Number: 1056 Registered: Sep-06
| Posted on Sunday, March 18, 2007 - 12:49 am: |
What ohm is the sub? And how much do you want to spend on a amp? |
Post Number: 2 Registered: Mar-07
| Posted on Sunday, March 18, 2007 - 12:54 am: |
its dual 4 ohm. and i really don't wanna spend more than 250 or 300 bucks. |
Silver Member Username: Nd4spd18
Southeast PA
Post Number: 941 Registered: Jul-06
| Posted on Sunday, March 18, 2007 - 01:06 am: |
Kicker kx1200.1 There are some on ebay for some dam good prices right now.... |
Southeast PA
Post Number: 943 Registered: Jul-06
| Posted on Sunday, March 18, 2007 - 01:08 am: |
Oh damit scratch that --- I didn't see the dual 4 ohm.... In that case you need an amp that does 1000 watts at 2 ohms. |
Post Number: 1058 Registered: Sep-06
| Posted on Sunday, March 18, 2007 - 01:14 am: |
william Try this out http://www.techronics.com/index.cfm?fuseaction=product.display&Product_ID=2869 |
