Home > Message Board > Car Audio > Amplifiers > Archive through March 23, 2007 > Amplifier tuning?
Author Thread: Amplifier tuning?
Username: Jaguar600
Post Number: 89
Anyone know of any sites that tell how to tune your amplifier? More exact any sites that have bass test downloads or anything?
Username: Skies
Courtenay, British Colu...
Post Number: 412
What do you mean, "tune your amplifier"?
You can't do anything, other than add distortion, otherwise known as Bass Boost.
A watt is a watt, there is no changing it.
Username: The_image_dynamic
San Diego
Post Number: 574
He means "tuning" the gain, crossovers etc.
You can get test tones and bass songs here (click on the Downloads tab):
http://www.realmofexcursion.com/main.html
Username: Blainew
Post Number: 2319
to tune your gain.......
figure out your input sensitivity.. i did this today so i will use my numbers...
my gain goes from .002 to 7 volts so i made notches on a piece of paper, from 0-7
01234567
then, you find your volts of your head unit...mine is 2
so obvoisly i would put my gain at the # 2 notch. then you can easily guage how much you would need to turn your gain..... (about three fourths in this case)
Username: Blainew
Post Number: 2320
^^that might be confusing...
Username: Jaguar600
Post Number: 108
haha yeah especially that my head unit is a PEICE
Its a pyle.....
Username: N2audio
Lawrence, Ks
Post Number: 1246
http://www.caraudio.com/forum/showthread.php?t=164826
Home > Message Board > Car Audio > Amplifiers > Archive through March 23, 2007 > Amplifier tuning? [ « Previous ] [ Next » ]
