Thread: Easy amplifier question... |
Bronze Member Username: Jaguar600
Post Number: 88 Registered: Jul-05
| Posted on Friday, March 16, 2007 - 05:50 pm: |
Hey guys I just got the kenwood KAC-9102D and I noticed it has 2 outputs for speakers, a left and a right. I just have one sub I connected to the left channel is that right? Why are there left and right channels if its a mono amp? |
Bronze Member Username: Jeromebaker
Post Number: 85 Registered: Dec-05
| Posted on Friday, March 16, 2007 - 07:03 pm: |
It's one channel on the inside, it's just like that so you can wire more subs without having to have a big-as s terminal. If you have more than 1 sub then connect it to the right channel. If not then it's on yo if you want to leave it or what (I personally think subs always sound better in pairs... or quads... ). |
Post Number: 90 Registered: Jul-05
| Posted on Friday, March 16, 2007 - 07:04 pm: |
oh ok so then connected it to the left channel is fine? |
Silver Member Username: Nd4spd18
Southeast PA
Post Number: 922 Registered: Jul-06
| Posted on Friday, March 16, 2007 - 07:08 pm: |
It does not have left and right channels, it is one channel with four terminals. Now, if you just bought that amp, RETURN IT ASAP. Kenwood is one of the worst brands of amplifiers out there. If you don't believe me search the forum for threads about kenwoods with blown power supplies. |
Post Number: 86 Registered: Dec-05
| Posted on Friday, March 16, 2007 - 07:15 pm: |
Yeah, MS is right. Kenwood amps aren't very good, regardless of what andre nickatina says. But if you are going to keep the amp you'll be fine the way you have it, as long as you like the sound. |
Silver Member Username: Jaguar600
Post Number: 101 Registered: Jul-05
| Posted on Wednesday, March 21, 2007 - 02:16 pm: |
I Think it sounds great actually... and its a class D. I dont really think I will have to worry about a blown power supply the amp is only at 4 ohms, I'm not even close to the max |
