Thread: What amp? |
Bronze Member Username: Turnmat
Post Number: 59 Registered: Feb-07
| Posted on Friday, March 16, 2007 - 12:36 am: |
I am getting a Audioque hd3 dual 2 ohm 15" sub and i plan on getting 1 or 2 Hifonics amps for it... 1 Bxi2006D 1-2 Bxi1606D or 2 Bxi1206D thanks, matt |
Silver Member Username: Oleg
Santa Monica,
CA
Post Number: 640 Registered: Nov-04
| Posted on Friday, March 16, 2007 - 12:11 pm: |
Why hifonics? are you not open to other brands? |
Post Number: 62 Registered: Feb-07
| Posted on Friday, March 16, 2007 - 12:36 pm: |
i heard that they put out good power for the money |
Silver Member Username: Killswitchjd
Post Number: 310 Registered: Apr-06
| Posted on Friday, March 16, 2007 - 01:25 pm: |
directed audio. check those out on a budget, not sure how much power you need but for under 300 you can get 1200x1 at 1 ohm... |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 4270 Registered: Dec-05
| Posted on Friday, March 16, 2007 - 01:45 pm: |
kicker kx 1200.1 |
Silver Member Username: Imalik
Jackson,
New Jersey
Ocean
Post Number: 147 Registered: May-06
| Posted on Friday, March 16, 2007 - 03:18 pm: |
The Hifonics amps are great budget amps, what your going to spend on the 2006 you can get the kicker kx 1200.1 for that price off of ebay |
Post Number: 63 Registered: Feb-07
| Posted on Friday, March 16, 2007 - 04:59 pm: |
thanks for the suggestions guys i need about 2000 watts rms... but i will take a look on ebay... |
Santa Monica,
CA
Post Number: 645 Registered: Nov-04
| Posted on Friday, March 16, 2007 - 05:06 pm: |
orion hcca-d5000 or a similarly powered US amps. |
Post Number: 64 Registered: Feb-07
| Posted on Friday, March 16, 2007 - 11:12 pm: |
what about this amp? http://cgi.ebay.com/New-4400W-RMS-Amplifier-MA-Audio-HK802SX-2-1-Channel-NR_W0QQ itemZ110103937057QQcategoryZ79819QQrdZ1QQcmdZViewItem Do you think that is to much power? |
Silver Member Username: Sheriff
Post Number: 110 Registered: Jan-07
| Posted on Friday, March 16, 2007 - 11:41 pm: |
Don't get that MA Audio amp. MA audio is know for making poor quality amps. |
Post Number: 65 Registered: Feb-07
| Posted on Friday, March 16, 2007 - 11:46 pm: |
ok sounds good...what do you think one amp or two? this is going into a show car...i thought that two amps one on ecah side of the sub would look best...any suggestions? also what about this amp http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem%26%26item%3D220090959192&ssPageNam e=STRK:MEWA:IT&ih=012 or http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem%26%26item%3D220090959192&ssPageNam e=STRK:MEWA:IT&ih=012 thanks again, matt |
Santa Monica,
CA
Post Number: 646 Registered: Nov-04
| Posted on Saturday, March 17, 2007 - 01:04 am: |
It just may be the best 1500 clean watts for that price. |
Gold Member Username: 420alldaylong
Post Number: 1050 Registered: Sep-06
| Posted on Saturday, March 17, 2007 - 01:11 am: |
matt How much do you want to spend on a amp? |
Post Number: 68 Registered: Feb-07
| Posted on Saturday, March 17, 2007 - 01:12 am: |
do you think its worth it? and this was the other amp i was talking about http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ih=014&sspagename=STRK%3AMEWA%3AIT &viewitem=%26item%3D330099404427%26%26 |
Post Number: 69 Registered: Feb-07
| Posted on Saturday, March 17, 2007 - 01:14 am: |
nvm guess it was removed or something...but it was for a MMATS D2001.1 amp |
Post Number: 70 Registered: Feb-07
| Posted on Saturday, March 17, 2007 - 01:15 am: |
$350 to 400 |
Post Number: 1051 Registered: Sep-06
| Posted on Saturday, March 17, 2007 - 01:27 am: |
matt Sundown SAZ 1500D $450 |
Post Number: 74 Registered: Feb-07
| Posted on Saturday, March 17, 2007 - 01:31 am: |
i dont have 450 right now...working on a tight budget...i am having Mark build me a box and the sub set me back a good bit maybe in a few weeks... |
Post Number: 1052 Registered: Sep-06
| Posted on Saturday, March 17, 2007 - 01:38 am: |
They this out better than Brutus http://www.ikesound.com/product-product_id/4167 |
Post Number: 77 Registered: Feb-07
| Posted on Saturday, March 17, 2007 - 01:46 am: |
matt likes... i will most likly get one next week some time but do you think i should get a second one? |
Post Number: 1053 Registered: Sep-06
| Posted on Saturday, March 17, 2007 - 01:53 am: |
One will be fine. What kind of box will you be using? |
Post Number: 80 Registered: Feb-07
| Posted on Saturday, March 17, 2007 - 01:57 am: |
it is going to be a tcab box like the one at the bottem of page two with the two type R subs http://www.thecaraudiobox.com/boxpics/2.html |
Post Number: 89 Registered: Feb-07
| Posted on Sunday, March 18, 2007 - 01:27 am: |
what do you think? |
Post Number: 90 Registered: Feb-07
| Posted on Sunday, March 18, 2007 - 01:43 am: |
i was also thinking about a Orion amp...the ORION HCCA 275 R tell me what you think |
