Thread: HEY!! Oleg |
Bronze Member Username: Pete_the_pup
Gaffney,
Sc
Usa
Post Number: 12 Registered: Feb-07
| Posted on Thursday, March 15, 2007 - 12:22 pm: |
You recommended the ORION HCCA-D2400 for my set up. P/A FUBR-10's You said to let you know how i liked it. I love it. When I crank it up there is so much sound pressure it makes breathing a noticable job. You Da' Man Dude Thanks |
Silver Member Username: Oleg
Santa Monica,
CA
Post Number: 628 Registered: Nov-04
| Posted on Thursday, March 15, 2007 - 08:03 pm: |
Nothing beats advice when someone has actually tested the stuff. We beat the amp senseless and that's the best test I can give it lol I'm glad you like it...never gets hot, eh? |
Gaffney,
Sc
Usa
Post Number: 13 Registered: Feb-07
| Posted on Friday, March 16, 2007 - 07:28 am: |
I mounted it under the driver seat, and so far it hasn't even got real warm. I only have 1 sub wired up right now. 1 ohm load. the only way i could wire 2 it would be 2ohm or 1/2ohm or get different subs with dual 4ohm v/c. |
Santa Monica,
CA
Post Number: 636 Registered: Nov-04
| Posted on Friday, March 16, 2007 - 09:45 am: |
*cough*different subs*cough* lol Read this thread... http://forum.ecoustics.com/bbs/messages/4/278071.html dude is running it at .44ohm load. |
Santa Monica,
CA
Post Number: 637 Registered: Nov-04
| Posted on Friday, March 16, 2007 - 09:57 am: |
Oh and I'd try to add the other sub, too. Series each sub's coils and then parallel the subs together to get 2ohms. See how they sound, if good...problem solved. Damping factor will also increase with the increased resistance. |
Gaffney,
Sc
Usa
Post Number: 14 Registered: Feb-07
| Posted on Friday, March 16, 2007 - 10:13 am: |
So I could run it a .5 ohm as long as i keep an eye on the temp. like with a infrared thermometer. If it starts getting hot turn it down or turn it off? |
Santa Monica,
CA
Post Number: 638 Registered: Nov-04
| Posted on Friday, March 16, 2007 - 10:18 am: |
I can't personally recommend that b/c I don't want you to ruin your stuff. It seems to have worked for that guy and I don't think it'll overheat, but you would need to keep an eye on it. I don't want to tell you to try it, then have it mess up...I'd feel bad. If you feel like it'll work, try it. I'd actually try the 2ohm load first and see how you like that. |
Bronze Member Username: Mmaudioconcepts
Murray,
KY
Post Number: 98 Registered: Jan-07
| Posted on Friday, March 16, 2007 - 10:51 am: |
how r those FUBR working for you,,,on hear they say they suck...but from people i know ive been told they are great spl subs |
Gaffney,
Sc
Usa
Post Number: 15 Registered: Feb-07
| Posted on Friday, March 16, 2007 - 11:05 am: |
For me they "kick butt" and take names. I've had um' in a GT40 with a BOSS RIPPER amp and they would blow your head off becouse they were right behind you at shoulder level. The mids and tweets didn't have a chance. If SPL means Sound Pressure Level. Yes they can and will (i won't use the word hurt) but i'll say make it uncomforatable to be in close proximity. |
Santa Monica,
CA
Post Number: 639 Registered: Nov-04
| Posted on Friday, March 16, 2007 - 11:59 am: |
Do they sound good at all or are they sloppy? Do they hit a lot harder with the orion? |
Gaffney,
Sc
Usa
Post Number: 16 Registered: Feb-07
| Posted on Friday, March 16, 2007 - 12:32 pm: |
With the Boss they were quite muddy. It didn't have the freq. adj. like the Orion. I mostly listen to hard classic rock which is more melodic than todays music that has the HIT in which you speak, but yes with the Orion the bass is tighter, cleaner and I have to keep adjusting my rearview mirror cause it vibrates loose. (the only thing i ain't done is glued it in place)and that's with just 1 10" sub. |
Murray,
KY
Post Number: 99 Registered: Jan-07
| Posted on Friday, March 16, 2007 - 12:46 pm: |
have you heard the MOFOs? |
Gaffney,
Sc
Usa
Post Number: 17 Registered: Feb-07
| Posted on Friday, March 16, 2007 - 01:04 pm: |
No! I can't say that i have. I'm no expert or can not even say knowledgable about drivers and such, but i know what i like. I have found that even a cheap driver can sound good in a box built for it or a tpo off the line driver will sound like crap in a box made like it. |
Santa Monica,
CA
Post Number: 641 Registered: Nov-04
| Posted on Friday, March 16, 2007 - 01:46 pm: |
Cool cool...so are you gonna try hooking up the 2nd sub? I wanna see how it goes |
Gaffney,
Sc
Usa
Post Number: 18 Registered: Feb-07
| Posted on Friday, March 16, 2007 - 01:54 pm: |
Yeeeah! (that southern for yes) I have a sealed box made for the FUBR. I can mount one in it and plug um' in and see what falls off my truck next!! |
Santa Monica,
CA
Post Number: 642 Registered: Nov-04
| Posted on Friday, March 16, 2007 - 01:58 pm: |
you're saying your box only lets you hook up 1 at a time? |
Gaffney,
Sc
Usa
Post Number: 19 Registered: Feb-07
| Posted on Friday, March 16, 2007 - 02:03 pm: |
yes! they're individual boxes. I have (2) .5 cu. ft. sealed boxes and 1 ported tube that i made. |
Santa Monica,
CA
Post Number: 643 Registered: Nov-04
| Posted on Friday, March 16, 2007 - 02:10 pm: |
ahhhh alright lemme know when you do it....pics?? |
Gaffney,
Sc
Usa
Post Number: 20 Registered: Feb-07
| Posted on Friday, March 16, 2007 - 02:19 pm: |
I don't have access to a scanner and besides I'm at work, ( don't have a computer at home, I have to pack a lunch to go to the mail box) I'm gonna try it this weekend and i'll fill ya' in Monday. Besides my homade tube ain't purr-dy, but it rocks the truck |
Santa Monica,
CA
Post Number: 644 Registered: Nov-04
| Posted on Friday, March 16, 2007 - 02:55 pm: |
lol sounds good! |
New member Username: Soke
Post Number: 10 Registered: Mar-07
| Posted on Friday, March 16, 2007 - 05:40 pm: |
...owwwwwwwwwwww |
Gaffney,
Sc
Usa
Post Number: 21 Registered: Feb-07
| Posted on Monday, March 19, 2007 - 08:47 am: |
Well!! I did it. Hooked up both subs and thanks to "Oleg" my truck not only provides valuable transportation, it now has therapeutic properties. When i get a sore back I just put in the earplugs, load up "Rush" 2112 "AHHHH" instant massage. Just a hair past half volume the metal building about 20 ft. from where I park starts to rattle. PtP is a Happy "REDNECK" thanks again Oleg. Pete The Pup |
Santa Monica,
CA
Post Number: 657 Registered: Nov-04
| Posted on Monday, March 19, 2007 - 01:07 pm: |
haha you're funny, man. Enjoy! ttyl |
