Home > Message Board > Car Audio > Head Units > Archive through March 13, 2007 > A problem with my eclipse head unit?
Author Thread: A problem with my eclipse head unit?
Username: Longbluesquid
Post Number: 125
ok so i have an eclipse cd4000 installed in my moms ford windstar. so when i drive over speed bumps the radio cuts off and yesterday i drove over a big speed bump and the radio just doesnt work anymore... so im thinking its the ground wire anyone have any idea what it could be?
Username: Tweek
Port Orchard, Washington
Kitsap
Sounds like the ground wire to me. Either that, or maybe you should check the harness plug in the back of the head unit.
I have a CD8053 that I purchaced in 2004, and recently performed a faceplate relocation to above my rear veiw mirror. Works wonderfuly and I have found it easier to use while driving. I never liked using the remote.
Hope everything turns out for you! -Thomas(aka Tweek)
Home > Message Board > Car Audio > Head Units > Archive through March 13, 2007 > A problem with my eclipse head unit? [ « Previous ] [ Next » ]
