Home > Message Board > Car Audio > Amplifiers > Archive through March 23, 2007 > HK 4000D or XX colossus??
Author Thread: HK 4000D or XX colossus??
Username: Thomas_g
NM
Post Number: 2210
What do you think would be better, more powerful, the MA Audio HK 4000D or the Hifonics XX Colossus, which would you get?? Thanx.
Username: 420alldaylong
Post Number: 1005
Out of those two amps I would get the Hifonics XX-Colossus. My opinion
MA Audio needs 17 volts for rated power.
Hifonics XX-Colossus needs 14.4 volts for rated power.
Username: Th3pwn3r
Chicago, Illinois
U.S.A
Post Number: 1315
I've seen the Hifonics XX Colossus run and it was pretty impressive for the money.I've never seen that MA amp run though so...I just thought I'd say that Colossus is a pretty solid amp.
Username: Chaunb3400
Huntsville, Alabama
U.S.
Post Number: 11707
HIFO
Username: Sheriff
Post Number: 77
Go with HIFONICS. MA Audio amps aren't that great.
Username: Thomas_g
NM
Post Number: 2213
Kool thanx guyz i really appreciate all the input, another question, how big is the colossus really, some say its 30 inches, some say its 40, does anyone know the real size of it?? I could get a moded HK 4000D for $399, should i go with the HK, the cheapest i could get the xx colossus is $700, both are on sonicelectronix, but i think the HK4000d is like $900 there.
Username: Oleg
Santa Monica, CA
Post Number: 545
Both amps are about $640 shipped on eBay. Colossus II is 26.5in long.
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 4250
XX colossus= better quality and they both have similar power output.
Username: Oleg
Santa Monica, CA
Post Number: 552
So we're saying go with the Colossus II. Consider yourself helped
Username: Thomas_g
NM
Post Number: 2214
kool i do thank you guys, now do you think 2 18" Q's, or 2 18" BL's?? Thanx.
Username: Skies
Courtenay, British Colu...
Post Number: 398
Q's for SQL.
BL's for SPL.
I'm quite sure that's how it goes, although I have been out of it for awhile. Someone correct me if I'm wrong :-)
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 4256
i'd try 2 Qs. Cuz at those levels, it will get loud
Username: Thomas_g
NM
Post Number: 2215
kewl thanx tyler and Juliob, xx colossus it is!!! Do you think ima have to run 1 gauge??
http://www.sonicelectronix.com/item_3935.html
That should do right??
Few more questions im new to the whole alt, and batt scene. What size of alt, and why do people use yellow tops?? Thanx ALOT guyz!!
Username: Oleg
Santa Monica, CA
Post Number: 564
That amp kit will be fine, but you also need some RCA cables with that. You will most likely need a high output alt to ensure the amp gets enough power, otherwise you're risking blowing your car's charging system and even breaking your stereo equipment. Yellow tops by Optima (people also use kinetik, stinger, etc) are deep cycle batteries, which don't get damaged after a few times of complete discharge, like regular batteries do. This allows you to play your stereo while the car's off and if used as a starter battery, you won't have a problem with a dead battery. Both, alternator and deep cycle battery, are pretty much essential with your setup.
Username: Thomas_g
NM
Post Number: 2216
kewl thanx ya i got a pretty good $50 dollar pair of RCA's. Where do they sell yellow tops?? Well do they just add a yellow top or do they only change to a yellow top cuz they like add it in the back, do you know how much those cost??
Username: Oleg
Santa Monica, CA
Post Number: 566
I got my yellow top from autozone for $180 or so, but they have them on eBay cheaper - be sure to check for the size that you need. If you get a high output alternator, which everyone here recommends, you'll just replace your stock battery with the yellow top, upgrade the "big 3," and you'll be all set.
Big 3 is:
1) Battery negative to chassis
2) Alternator to battery positive
3) Chassis to engine
Username: Big_fletch
Newport, Ar, Ar
United states
Post Number: 638
yeah i juss got a colossus amp and mine is 41 inches long but the newer ones are 28 inches long same output but different size and still tryin to figure out what subs to get but if u like loud subs go with (2) 18" BL subs fully loaded
Username: Tremor1127
Fi Car Audio has got m...
Post Number: 1165
hey fletch, are you running 18" BLs?
it feels cool to call someone fletch, as i am a fletch(er) myself... :-)
Username: Thomas_g
NM
Post Number: 2217
Hey Tyler, is yours a colossus xx 2??
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 4258
YEAH TJ! bass freak. Get those yellow tops on ebay or PM chad lee. Nice choice there. IF i were you, i'd use 0AWG.
Username: Thomas_g
NM
Post Number: 2220
lol Juliob, you know how all of us bass heads are!!
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 4269
Newport, Ar, Ar
United states
Post Number: 645
tremor1127 my real name is tyler fletcher everyone just calls me "fletch" but yea i have the colossus xx amp its powerful dont get me wrong on that any thing u feed it it will push it but one of my channels on the amp isnt working right now and i dunno what's wrong with it so im gonna look at it and either send it back or sell it
Username: Turnmat
Post Number: 93
Hey Fletch if you sell the amp i will buy it...if the price is right
Home > Message Board > Car Audio > Amplifiers > Archive through March 23, 2007 > HK 4000D or XX colossus?? [ « Previous ] [ Next » ]
