Home
Message Board
Car Audio
EQs and Crossovers
> EQ setting?
Main Topics
Your Account
Search
Help
Last 3 Days
Author
Thread: EQ setting?
ivan jacobs
Username: Theivan
Dawson Creek, British Colu...
Posted on Saturday, March 03, 2007 - 01:51 pm:
i want a really deep bass eq setting to really push my sub. Amp is a JL 500/1 I have an Infrasonic Sensor between 15 and 60 hz and for my bass eq i have:
Q(bandwith) = 0.5 to 40
Center Freq = 20-80
Boost (dB) = 0-+15
mostly for rap music. Any ideas?
Relevant Product Info
M.S.
Username: Nd4spd18
Southeast PA
Post Number: 703
Posted on Saturday, March 03, 2007 - 02:44 pm:
You don't want to be using bass boost to adjust the volume of the bass.
If you add boost after you set the amps's gain, your amp will clip when you turn up the volume.
Post:
-Color-
Black
Red
Green
Blue
Yellow
Purple
Orange
Cyan
Gray
White
-Font-
Arial
Courier
Symbol
Times
Verdana
-Size-
Tiny (-2)
Small (-1)
Normal
Large (+1)
Huge (+2)
Username:
Need to Register?
Password:
Forgot Password?
Options:
Enable HTML code in message
Action:
Topics
Last Day
Search
Formatting Tips
Terms
Rules
Help
Log out
Home
Message Board
Car Audio
EQs and Crossovers
> EQ setting?
Previous
Next
