Home > Message Board > Car Audio > Head Units > Archive through March 13, 2007 > AUX input help
Author Thread: AUX input help
Username: Dreamtheater
Post Number: 114
i heard you can buy a wire to put in your cd changer that will give you the 2 RCA inputs and work like the auxiliary wire.. i need one for my panasonic headunit since it does not have AUX input can anybody help me?
Username: Dkchillin
Vermont
Post Number: 396
Would need to know what Panasonic deck to tell you what adapter. Panasonic is one of the few companies that doesn't have a slew of options. If you give us the model number of the deck we can probably help you out.
If this is for an iPod, Panasonic makes an iPod cable that works with some of their decks.
Post Number: 115
naah not an ipod.. regular mp3 .. so i was looking for just a headphone jack.. model number is CQ-DFX683U
Username: Arande2
Extreme SQ FTW
Post Number: 1781
Funny seeing you here..
Post Number: 117
me? who are you?
Username: Arande2
Extreme SQ FTW
Post Number: 1805
If this doesn't ring a bell...then it's not you.
"Building A Live PA Rig"
Post Number: 119
nope no clue what your talking about..you talking about a thread or something? i only post in the subwoofers forum.. occasionally the amplifiers..
Username: Dkchillin
Vermont
Post Number: 399
Unfortunately, Panasonic is one of the few major manufacturers who have sort of missed the AUX-In boat. Nearly all the other companies offer either built in AUX ports, or a way to convert the changer port (like you were saying) but unless you have a Panasonic deck with a built in AUX port, you're out of luck. Wish I had better news.
Home > Message Board > Car Audio > Head Units > Archive through March 13, 2007 > AUX input help [ « Previous ] [ Next » ]
