Home > Message Board > Car Audio > Head Units > Archive through March 13, 2007 > Cut wires now nothing inside works
Author Thread: Cut wires now nothing inside works
Username: Bob123131
So i was getting ready to install deck and i cut the ariginal harness baout an inch back from the plug right then all interior stuff turned off and dont work. My fuses look fine.
Username: Chaunb3400
Huntsville, Alabama
U.S.
Post Number: 11638
lol..why did u do that??
Username: Bob123131
well i have installed tons of car stereos and there is no point in 10 dollars on one of those harneses except for the fact that it is easier to put stock stero back in. Once you cut them you just test for power etc and you are good to go, but i fryed something or something I know it was dumb, but now i need to get over that and find a sollution.
Huntsville, Alabama
U.S.
Post Number: 11641
hmm $10 doesnt seem so bad now does it....
Never ever cut the factory harness...thats just plan not good...
what kind of car is it??
Username: Adddisorder
West palm, Florida
Post Number: 3566
haha damn that was dumb if you ask me. sound like you blew a fuse look in the fuse box in the car kick pannel
Home > Message Board > Car Audio > Head Units > Archive through March 13, 2007 > Cut wires now nothing inside works [ « Previous ] [ Next » ]
