Thread: Speaker Recommendations |
Roland |
| Posted on Monday, June 09, 2003 - 01:57 pm: |
Am looking for high end 6.5" component speakers, but need recommendations on what brand to buy. I was looking at Focal (165K) and Diamond Audio Hex (S600). I read the Focals don't emphasize the lows too good and I read a good review on the Diamonds. I listen to rock, mostly, and like to be able to hear the lows, mids & highs clearly and very defined. Can anybody recommend any other brands or give me feedback from the above brands? |
Derek |
| Posted on Tuesday, June 10, 2003 - 02:00 pm: |
Try Morel and Dynaudio. If you want something cheaper, try MB Quart or Infinity Kappa (Car) speakers. |
Zeljko |
| Posted on Tuesday, July 29, 2003 - 12:46 am: |
DLS ultimate refference are the best speakers you can buy , but not cheap |
adam hutsell |
| Posted on Wednesday, July 30, 2003 - 11:51 am: |
Derek knows his stuff!! Listen to him and u will get far haha. I got kappas, they rock hardcore, but u need an amp for those if u get any of the four he mentioned. |
Jof |
| Posted on Wednesday, July 30, 2003 - 12:23 pm: |
I would get Focal's with an accurate, not boomy sub. IMO, components are meant to be used with good subs. |
| Posted on Sunday, August 03, 2003 - 07:04 pm: |
I've used Boston Acoustics Pro Series 6.5 components and loved them. They are a very smooth and even set. |
