Home > Message Board > Car Audio > Disc Changers > Chrysler Sebring CD Changer
Author Thread: Chrysler Sebring CD Changer
Username: Anreill
Have a factory installed CD Changer in an 02 LXI. When the changer is connected and the power is turned on, it flashes the 1-4 lights and the Ready light several times. Then the 1 & 2 slot lights flash, then 3 & 4, and it repeats. It won't take a CD and I can't get the (also factory) stereo to switch over to CD mode. Is this a simple error code type of thing I can fix, or does it need to be replaced?
Relevant Product Info
Username: Ricardoagain
Hi Tyler,
I have a very simlar problem. My 2000 Chrysler Concorde LXI has the same 4 disc changer. The original broke (literally the insides came apart) so I bought a used one, just installed. All lights blink in unison and won't stop. Did you have any luck in repairing yours?
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Car Audio > Disc Changers > Chrysler Sebring CD Changer [ « Previous ] [ Next » ]
