Thread: Dash lights Help |
New member Username: Alex2k2
Post Number: 1 Registered: Feb-07
| Posted on Tuesday, February 27, 2007 - 06:26 pm: |
what up my peeps/.. i need help i installed a new deck on my 98 honda accord but now my dash panel lights dont turn on anymore can anyone help me out with this.. i checked all of the fuses and they ckecked out fine.. what should i do thanks |
Silver Member Username: Oleg
Santa Monica,
CA
Post Number: 473 Registered: Nov-04
| Posted on Thursday, March 01, 2007 - 11:58 pm: |
You'd usually have a dimmer turn know somewhere on the dash to dim/brighten those lights...check that. |
Bronze Member Username: Jesse59672
OK
Post Number: 65 Registered: Feb-07
| Posted on Friday, March 02, 2007 - 12:02 am: |
double check the fuses thats the only thing i can think of. |
Bronze Member Username: Aaronjp1990
Lerwick,
Shetland
Uk
Post Number: 50 Registered: Apr-06
| Posted on Friday, March 02, 2007 - 02:50 am: |
loos wire maby? |
Post Number: 2 Registered: Feb-07
| Posted on Friday, March 02, 2007 - 02:58 am: |
what up my peeps/.. i need help i installed a new deck on my 98 honda accord but now my dash panel lights dont turn on anymore can anyone help me out with this.. i checked all of the fuses and they ckecked out fine.. what should i do... i ll be a little more detailed.. my problem is that when i have my headlight off some if the lights on my dash turn on ... but when turn on my headlights my dash lights go out as well as the ones on my the climate control.. i re connected the deck and the problem is still ther.. the dimmer is not working and the my harness has no place for the illumination wire which is orange.. can any one help!!PLZ thanks |
