Home > Message Board > Car Audio > Head Units > Archive through March 13, 2007 > Amp bypass harness?
Author Thread: Amp bypass harness?
Username: Liqdfire3
Lee high acres, Florida
Post Number: 113
is there such a thing. a friend of mine just got a 2004 honda civic and wants to keep the stock radio but adding an amp and sub. i have seen alot of people running and amp and sub off their stock HU but i didnt know what kind of harness they were using. any can help me out on where to find one?
Username: Scorpionzero454
Post Number: 76
it's called a hi-low converter. http://cgi.ebay.com/PYLE-PLVH-L60-2-CHANNEL-HI-LOW-CONVERTER-NEW_W0QQitemZ330082 629284QQihZ014QQcategoryZ50552QQrdZ1QQssPageNameZWD1VQQcmdZViewItem
Username: Racerdude15
Indianapolis, Indiana
or u could just get an amp with a high-power input
Username: Nd4spd18
Post Number: 498
Ryan, DO NOT buy anything made by pyle! Josh is also wrong.
When you need is called a JL audio cleansweep, or similar device.
http://mobile.jlaudio.com/products_cleansweep_pages.php?page_id=94
It will remove any equalization or other unwanted crap from the factory stereo's signal, and allow you to add aftermarket amplifiers.
Post Number: 77
just giving him an example
Username: Nd4spd18
Southeast PA
Post Number: 566
Oh ok, but a converter like that will still not work on some factory stereos where the signal has already been run through built in EQs, X-overs, etc.
Home > Message Board > Car Audio > Head Units > Archive through March 13, 2007 > Amp bypass harness? [ « Previous ] [ Next » ]
