Thread: Bridging? |
New member Username: Mrshoehorn
Post Number: 3 Registered: Feb-07
| Posted on Wednesday, February 21, 2007 - 04:23 pm: |
I want to get a 4 ch. amp instead of a 5 ch. to save some cash. I've got four 50 W RMS speakers and one 10" 250 W RMS sub. I would like to bridge the speakers and sub so I won't have to purchase a 4 ch. amp. Is this possible? If so, how do I wire them? Thanks ~Shoe |
Gold Member Username: Adddisorder
West palm,
Florida
Post Number: 3373 Registered: Jan-06
| Posted on Wednesday, February 21, 2007 - 05:14 pm: |
read what you just wrote it doesnt even make sense. I want to get a 4 ch. amp instead of a 5 ch .....so I won't have to purchase a 4 ch. amp. |
Post Number: 4 Registered: Feb-07
| Posted on Wednesday, February 21, 2007 - 06:15 pm: |
Relax, sorry. I want to get a 4 ch. amp so I don't have to purchase a 5 ch. amp. I have found an answer to my question, but thanks anyways. New question and sorry if I am a nuisance. Would it be ok to run a 2 ohm amp to 4 ohm speakers? Or would that not work, or just affect the sound quailty? ~Shoe |
West palm,
Florida
Post Number: 3386 Registered: Jan-06
| Posted on Wednesday, February 21, 2007 - 09:21 pm: |
it will work fine, the speakers determine the ohm load the amp sees. if its a 4ohm speaker on each channel the amp will see 4ohms to get two ohms you can wire two 4ohm speakers in parallel then the amp would see 2ohm |
Silver Member Username: Basssquared
Post Number: 205 Registered: Nov-06
| Posted on Wednesday, February 21, 2007 - 10:27 pm: |
hey what happens if you bridge both of the channels in a mono block amp because my mono block amp has two channels just wondering? |
Gold Member Username: N2audio
Lawrence,
Ks
Post Number: 1203 Registered: Mar-04
| Posted on Wednesday, February 21, 2007 - 10:58 pm: |
not 2 channels, just two pairs of connections in case you need to run more than one speaker lead. |
