Home > Message Board > Car Audio > Amplifiers > Archive through February 22, 2007 > Risk?
Author Thread: Risk?
Username: Smoke05
Tucson, Arizona
U.S.
Post Number: 107
im planning on buying 2 alpine type r 12" which are 500rms each, either the dual 2 ohm to conectem at 2 ohms or the dual 4 ohms to connect them at 1 ohm. so here is my question. it is there a risk on running the amp at 1 ohm? (the amp is 1 ohm capable)like burning my car or frying my amp?. i will be using 4gauge cable.
thanks
Username: Hootz
Saskatoon, Saskatchewan
Post Number: 252
If it's 1 ohm stable, then no, no increased risk.
Username: Logan__tille
Imortal Box Building
Post Number: 6115
lol. If its 1ohm stable your ok. be sure you get 2 dual 4ohm subs though.
Username: Th3pwn3r
Chicago, Illinois
U.S.A
Post Number: 1070
You'll be fine if you run 2-Dual 4 ohm subs in parallel which will give you a Ohm load of 1.
Home > Message Board > Car Audio > Amplifiers > Archive through February 22, 2007 > Risk? [ « Previous ] [ Next » ]
