Home > Message Board > Car Audio > Amplifiers > Archive through February 22, 2007 > Is 1ohm or 2 ohm better??
Author Thread: Is 1ohm or 2 ohm better??
Username: Razzeldazzel06
Post Number: 223
What is better between a 1 ohm 1000 watt sub or a 2 ohm 1000 watt sub such offered by fi car audio??
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 4191
wiring configuration is the difference. Performance is the same.
However, in amps is not the same, cuz at lower impedances, efficiency decreases.
Run a Dual 1 ohm and a kicker zx 1000.1
IMO.
Username: Oleg
Santa Monica, CA
Post Number: 371
Keep in mind though that you MUST wire the coils in SERIES to get a 2ohm load because that kicker amps is 2ohm stable. So you'll need to get the dual 1ohm VC. If you get another amp (i.e.: kicker sx series), which is 1 ohm stable, you can get the dual 2ohm VC and wire them in PARALLEL down to 1ohm.
Home > Message Board > Car Audio > Amplifiers > Archive through February 22, 2007 > Is 1ohm or 2 ohm better?? [ « Previous ] [ Next » ]
