Thread: Hifonics vs phoenix gold |
Bronze Member Username: Smoke05
Tucson,
Arizona
U.S.
Post Number: 94 Registered: Jan-07
| Posted on Monday, February 19, 2007 - 10:29 pm: |
yeah, so im looking to power up 12" 2 alpine type R at 2ohm.. (i havent bought them yet, but i dont want to run them at 1 ohm because of the overheating plus i live at the desert) i want a budget amp 300 tops not more. thanks. |
Gold Member Username: Ctmike
Ct.
Post Number: 3416 Registered: Feb-06
| Posted on Monday, February 19, 2007 - 10:35 pm: |
here's some places to start, the first one being the cheapest: www.ebay.com www.onlinecarstereo.com www.woofersetc.com www.mainstreet-audio.com www.hifisoundconnection.com www.electronicexpress.com www.sonicelectronix.com www.speedsound.com |
Tucson,
Arizona
U.S.
Post Number: 95 Registered: Jan-07
| Posted on Monday, February 19, 2007 - 11:05 pm: |
thanks for the links, but which one will be better or are there others in the price range that are better. thanks |
Silver Member Username: Nd4spd18
Post Number: 425 Registered: Jul-06
| Posted on Monday, February 19, 2007 - 11:10 pm: |
They are both decent budget amps. |
Ct.
Post Number: 3419 Registered: Feb-06
| Posted on Monday, February 19, 2007 - 11:49 pm: |
pg isn't actually budget, not top of the line but not budget. maybe their octane series, but i'd still take an octane over a hifonics. if possible search around for a xenon 1200.1 (you might get lucky), that'd be perfect for them. try caraudio.com, every once in awhile someone has one for sale. |
Tucson,
Arizona
U.S.
Post Number: 97 Registered: Jan-07
| Posted on Tuesday, February 20, 2007 - 12:39 am: |
what about gto jbl1200.1 i can get it for 300 is it good or should i go with the octane series or the bxi.? |
Ct.
Post Number: 3422 Registered: Feb-06
| Posted on Tuesday, February 20, 2007 - 12:40 am: |
i'd take the jbl. |
Tucson,
Arizona
U.S.
Post Number: 98 Registered: Jan-07
| Posted on Tuesday, February 20, 2007 - 01:19 am: |
so then what would be better. is it worth to spend 100 more and buy a zx100.1 (kicker)rated at 1000 at 2 ohms or the jbl1200.1? rated at 1110 at 2 ohms |
Silver Member Username: Sinful_systems70
Post Number: 459 Registered: Nov-06
| Posted on Tuesday, February 20, 2007 - 02:13 am: |
Kicker |
Platinum Member Username: Chaunb3400
Huntsville,
Alabama
U.S.
Post Number: 11524 Registered: Jul-05
| Posted on Tuesday, February 20, 2007 - 04:18 am: |
I have a pg xenon 1200.1, i will sale... |
Tucson,
Arizona
U.S.
Post Number: 99 Registered: Jan-07
| Posted on Tuesday, February 20, 2007 - 04:27 am: |
well thanks, but im looking to buy new and with factory warranty. also here is a question... if i buy the zx1000.1 and the zx350.2 (for my 6.5) do i have to buy one or two of this http://sonicelectronix.com/item_7941.html?? it says dual amp. it is a 4 gauge. |
Silver Member Username: Oleg
Santa Monica,
CA
Post Number: 364 Registered: Nov-04
| Posted on Tuesday, February 20, 2007 - 12:37 pm: |
those are 4ga and 8ga kits, not sure it's what those amps use. Check their spec and make sure that's what you need. |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 4187 Registered: Dec-05
| Posted on Tuesday, February 20, 2007 - 12:46 pm: |
jbl gto 1201.1 FTMFW... or kicker zx1000.1 |
Silver Member Username: Rob932
Post Number: 125 Registered: Feb-05
| Posted on Tuesday, February 20, 2007 - 07:12 pm: |
i just sold my pcx1500 would of been perfect and i sold it cheap. |
Platinum Member Username: Rovin
1 12 Atomic ...
Post Number: 10768 Registered: Jul-05
| Posted on Wednesday, February 21, 2007 - 12:28 am: |
i hope ur subs r the 1222 which is the dual 2ohms model .... |
