Home > Message Board > Car Audio > Amplifiers > Archive through February 22, 2007 > Soundstream t4 dual 1 ohm sub? 1/2 oh...
Author Thread: Soundstream t4 dual 1 ohm sub? 1/2 ohm or 2 ohm
Username: Marshbotany
Mandan, Nd
US
will wiring the sub to 2 ohm draw less amps per watt ratio that having it at 1/2 ohm if the are both pulling the same wattage. what would be a good choice of an amp too. i was leaning toward a soundstream pca 1000d which is rated at 800rms at 2ohm
Mandan, Nd
US
also the sub is 900rms. would it be better to build a box for my hatch and if so is it better to face backwards/forwards, or upwards so it hits of the glass hatch. the box will be vented nontheless
Username: N2audio
Lawrence, Ks
Post Number: 1198
from several tests I've seen an amp will generally be less efficient at ultra-low impedances.
there are probably exceptions, but none come to mind.
As far as how to set up the sub. I used to have a Gen 2 RX7. I messed with several different box placements and found that placing it toward the rear of the car firing toward the rear gave me the best sound at the driver's seat.
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 4182
marshall try kicker zx 1000.1
Home > Message Board > Car Audio > Amplifiers > Archive through February 22, 2007 > Soundstream t4 dual 1 ohm sub? 1/2 oh... [ « Previous ] [ Next » ]
