Home > Message Board > Car Audio > Head Units > Archive through March 13, 2007 > Wiring Qustion for a 1991 ford taurus
Author Thread: Wiring Qustion for a 1991 ford taurus
Username: Packerfan51
Could i get a wiring diagram for a 1991 Ford Taurus LX please
Username: Ravenlock
So, I have a 91 ford escort. The previous owner basically ripped out all the existing stereo wires so i have to start completely from scratch (constant straight to battery, speakers, ground to body, etc). Does anyone know where the easiest connection would be for the switched and the illumination wires would be? Also, if anyone has step-by-step directions to wire a simple in-dash 60 watt cd player, that would be great. Thanks.
Username: Leew
XXXX!!WWWW, Yokosuka, ...
Holla Back Y...
Post Number: 1354
christoph mendez
This ZIP file is for you:
application/x-zip-compressedUpload
1991 Ford Escort Radio.zip (9.6 k)
This is original wiring from your car,you just match the wires from your new head unit to that schema that is all about!
good luck!
Username: Ravenlock
Thanks for the zip. Unfortunately, I couldn't open the file. Also, the car doesn't have the original wiring> It's literally a mess with all sorts of wires tangled, disconnected and pieced together.
Home > Message Board > Car Audio > Head Units > Archive through March 13, 2007 > Wiring Qustion for a 1991 ford taurus [ « Previous ] [ Next » ]
