Thread: Car amp on, car fuse blows |
New member Username: Treyo666
Post Number: 1 Registered: Feb-07
| Posted on Sunday, February 18, 2007 - 12:00 am: |
I need help deperately!!!. I have a toyota paseo 93, i have just bought a mtx sub and 2 ch pioneer 740 watt amp. Everytime i turn the car headlamps on with the car stereo on the fuse for tail lights blows. However if i put the headlamps on with the amp off its ok. What do you think i can do? Do you think a capacitor is needed? Should i just take it in to a car audio fixer dude or auto electrician? |
Silver Member Username: Sinful_systems70
Post Number: 415 Registered: Nov-06
| Posted on Sunday, February 18, 2007 - 12:06 am: |
No cap, wiring problem. |
Silver Member Username: Nd4spd18
Post Number: 325 Registered: Jul-06
| Posted on Sunday, February 18, 2007 - 01:00 am: |
^^^^ x2 And yes an audio shop would be able to fix that. |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 4171 Registered: Dec-05
| Posted on Sunday, February 18, 2007 - 09:58 am: |
^^^if they know what they're doing.. |
Post Number: 337 Registered: Jul-06
| Posted on Sunday, February 18, 2007 - 02:27 pm: |
^^^^ So true. A good audio shop would be able to fix that. |
