Thread: Component amp |
New member Username: Kyle7560
Post Number: 4 Registered: Feb-07
| Posted on Saturday, February 17, 2007 - 03:43 pm: |
I'm going to be purchasing a set of crystal sscs components but before i do i need to know if they will work with my amp. I'm very new to car audio and i don't know if i can hook components up to a 2 channel amp or if i need a 4 channel. I have a rockford p4002 if its possible to hook the components up to the 2 channel amp could someone please let me know how i can do this. |
Gold Member Username: Logan__tille
Imortal Box Building
Post Number: 5956 Registered: Feb-06
| Posted on Saturday, February 17, 2007 - 06:14 pm: |
whats the rms on thoes speakers? |
Post Number: 5 Registered: Feb-07
| Posted on Saturday, February 17, 2007 - 06:40 pm: |
100 |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 4168 Registered: Dec-05
| Posted on Saturday, February 17, 2007 - 08:06 pm: |
kyle. go to www.the12volt.com and hit the link woofer wiring. Is basically the same, but if you connect 4 speakers to a 2 channel amp, you lose the fade option |
