Thread: Kicker 1500.1 zx or kicker sx 1250.1 for 2 12" l7's |
Bronze Member Username: Lilpimpd
Post Number: 34 Registered: Jul-06
| Posted on Friday, February 16, 2007 - 06:14 pm: |
which amp??? |
Silver Member Username: Skibum12189
Cleveland
Post Number: 268 Registered: Mar-06
| Posted on Friday, February 16, 2007 - 07:22 pm: |
whats the voice coil configuration? If its dual 2 ohm vc's, get the zx, if theyre dual 4 ohms, get the sx |
Post Number: 35 Registered: Jul-06
| Posted on Sunday, February 18, 2007 - 05:13 pm: |
can i still wire dual 4ohm to a zx? or is it better to jus get 2 ohm subs?? cuz i want a 1500.1 zx bcs the sx only goes up to 1250.1!!?? |
Platinum Member Username: Chaunb3400
Huntsville,
Alabama
U.S.
Post Number: 11490 Registered: Jul-05
| Posted on Sunday, February 18, 2007 - 05:14 pm: |
"bcs the sx only goes up to 1250.1!!??" mine goes to 1503... |
Post Number: 36 Registered: Jul-06
| Posted on Sunday, February 18, 2007 - 05:20 pm: |
so the sx pushes more then 1250 watts! |
Cleveland
Post Number: 270 Registered: Mar-06
| Posted on Sunday, February 18, 2007 - 06:45 pm: |
yes, and the 1500 is prolly pushin nearly 1800. Generally, kicker amps are underrated. Also, Do NOT get dual 4 ohm L7s and plan to run it on a ZX. ZX series amplifiers are not 1 ohm ohm stable. SX and KX series ARE 1 ohm stable. So again, dual 2 ohm subs....get the zx, if you get dual 4 ohm subs, get the sx. You'll be happy with both, just the ZX will give it more power. |
