Thread: Memphis 1000d blowing fuses |
Bronze Member Username: Mrwebb
Post Number: 13 Registered: Dec-06
| Posted on Thursday, February 15, 2007 - 10:59 pm: |
Okay my memphis 1000d has been working perfectly fine this winter since i got it hooked up...this morning i go outside to warm up my car and as soon as the radio is turned on my two 40 amp fuses inside the amp pop...so i went and bought two 30 amp fuses to see if the amp was malfunctioning and they popped as soon as i turned on the switch...does anyone have any idea what could be causing this?? the amp has been mounted in one spot and no wires have been touched since it was originally installed. |
Gold Member Username: Blainew
Post Number: 2170 Registered: Nov-05
| Posted on Thursday, February 15, 2007 - 11:04 pm: |
happened to my amp oneday..... i must have gone thru 100 fuses....amp was defective.. |
Gold Member Username: Van_man
Boston South,
MA
Post Number: 2011 Registered: Mar-06
| Posted on Thursday, February 15, 2007 - 11:07 pm: |
Power wire shorting out. Check power wire |
Post Number: 15 Registered: Dec-06
| Posted on Thursday, February 15, 2007 - 11:49 pm: |
i have a 150 amp flat fuse ran inline with the power wire under the hood.... how can i tell if that fuse is blown and is causing my amp fuses to blow? |
Post Number: 16 Registered: Dec-06
| Posted on Friday, February 16, 2007 - 09:03 am: |
could the flat 150 amp fuse that runs under the hood be blown? |
Silver Member Username: The_image_dynamic
San Diego
Post Number: 318 Registered: Dec-06
| Posted on Friday, February 16, 2007 - 09:29 am: |
No because if that fuse was blown you wouldn't have any power to your amp at all. Who installed it? |
Post Number: 17 Registered: Dec-06
| Posted on Friday, February 16, 2007 - 05:39 pm: |
on the memphis 1000d the "yellow" fuse light is on and the "red" PRT light is on the fuse under the hood that runs into the power wire is fine so could my amp be blown? it was installed about 3 months ago by electronics express |
Post Number: 20 Registered: Dec-06
| Posted on Monday, February 19, 2007 - 06:34 pm: |
i found out both of y memphis 15's are blown some how or another so do i need to but 2 other 15's for my 1000d amp or try to send them for repair? if so where do i send them? |
