Thread: Are they getting enough power? |
Silver Member Username: Basssquared
Post Number: 172 Registered: Nov-06
| Posted on Thursday, February 15, 2007 - 09:19 pm: |
hey i have 2 12" kicker dual 4ohm L7 subs and i hooked them up to a audiopipe 4CLD 2400 watt amp and i know it gives 1200 watts rms at 1 ohm i thought it would be a good amp because i remember people saying that the KX1200.1 amp would be good for the L7s so i figured that another amp that does 1200 watts at 1 ohm would be good too but then i remembered that kicker underates their watts so would my audiopipe still be good enough for the 2 L7s they sounded really good but i dont know if im pushing them to what they should be |
Gold Member Username: Blainew
Post Number: 2167 Registered: Nov-05
| Posted on Thursday, February 15, 2007 - 10:46 pm: |
well those subs can take 1600 rms.for the pair.... but if that amp is really doin 1200 id keep it |
Bronze Member Username: Mmaudioconcepts
Murray,
KY
Post Number: 36 Registered: Jan-07
| Posted on Thursday, February 15, 2007 - 11:11 pm: |
the thing is the kx1200.1 puts out anywhere from 1350 to 1500 watts so not just any 1200 watt amp will do the same job as the kicker |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 4162 Registered: Dec-05
| Posted on Friday, February 16, 2007 - 12:51 pm: |
600w for each is decent. |
Post Number: 173 Registered: Nov-06
| Posted on Friday, February 16, 2007 - 04:35 pm: |
thanks a lot guys it sounds pretty good for now just making sure well thanks for the help once i get more money i might upgrade to a kicker amp but thats not for a while |
