Thread: Starting new system... |
New member Username: Killerdestroyer
Post Number: 1 Registered: Feb-07
| Posted on Wednesday, February 14, 2007 - 10:36 pm: |
Well, i am starting a system in my new car. I have a 10" Blaupunkt sub. in a well built box, from a friend. And, a 680watt Jensen JXP680 Amp, and wires. Now, i was wondering how i would go about hooking everything up. The main thing i dont understand is what do i do to hook up to my firewall? |
Silver Member Username: Freezeman_7
SSDs,
OK
U.S.A
Post Number: 692 Registered: May-06
| Posted on Wednesday, February 14, 2007 - 10:40 pm: |
not a thing to the firewall, u run your power wire through your firewall to your battery |
Silver Member Username: Quig
Pittsburgh,
Pa
Us
Post Number: 296 Registered: Sep-05
| Posted on Wednesday, February 14, 2007 - 11:48 pm: |
i suggest you start askin around for someone who knows what there doing, becuz if you think you hook something up to a firewall... then u shouldnt be touching anything in car audio, not being rude... but if you would like to know, you just run a power wire from your positive terminal battery into the 12v into ur amp, then ground it, and ur gona need a set of rca cables from your HU to amp, along with remote wire. |
Silver Member Username: Qbenjamin
Florida
Post Number: 275 Registered: Nov-06
| Posted on Thursday, February 15, 2007 - 01:14 pm: |
If I were you, I would get someone to help me.......Hook something up to the firewall ? If you can find it, I put up an entire thread on here about how to hook up an amp. It's very long, but it guides you step by step. |
