Home > Message Board > Car Audio > Amplifiers > Archive through February 22, 2007 > SOUNDSTREAM AMP
Author Thread: SOUNDSTREAM AMP
Username: Jynx
I'm looking at purchasing a soundstream amp for 2 solo-barics. I want this be loud as hell and want some advice on which one I should go with. XTA Tarantuala, ot Van Gogh. Info PLS.
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 4144
Bro. First, post some specs of those subs. Are they DVC 4 ohm or 2 ohm, what's their RMs ratings... many things and we will tell you a good amp
Username: Jynx
Don't worry about it.
Username: Rovin
1 12 Atomic ...
Post Number: 10722
look @ the PICASSO series which r monoblocks which r generally better for powering subs ....
Username: Freezeman_7
SSDs, OK
U.S.A
Post Number: 688
u kinda have to worry about it in order to buy the right amp. if you wont u will end up with your sh!t all messed up. look at your options first
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 4145
i'd say, two 12 CVX dual 4 ohm wired at 1 ohm with a soundstream ega 1700D or pca 1500d.
SSDs, OK
U.S.A
Post Number: 690
ill stick with julio on this one. good call
Username: Jynx
Post Number: 8
I'm pretty much stuck on the solo-barics. I heard the CVR and there not impressive to me. I heard nothing but good things about Soundstream so I believe I can go with either of the ones I want.
Username: Ctmike
Ct.
Post Number: 3393
who said anything about the cvr? he said cvx which is a better sub than any of the solo's.
Username: Th3pwn3r
Chicago, Illinois
U.S.A
Post Number: 1026
The CVX is definately not better than a Solo X. :-)
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 4149
^^^^ you're talking about SPL right? cuz if you're not, then try again-
Username: Oneracistguy
TWO EGG, FL
Post Number: 267
before u start getting into the big sound streams u need to make sure u have a heck of a charging system
SSDs, OK
U.S.A
Post Number: 695
true that^^ nice large ho alt, some nice huge 1/0 wire....etc etc
Username: Jynx
Post Number: 9
I called the tech support at Soundstream and the guy said definetly go with picasso 1500D. Thanks for the advice.
Username: 04redmach1
Columbus, GA
Post Number: 347
Of course Soundstream will tell you that. If you want a GOOD reliable amp to match those subs, considering you have DVC 4, look at the Sundown SAZ-1500D or the Cadence DCA1600.
Kevin
Username: The_image_dynamic
San Diego
Post Number: 330
To me this thread ended when the little pr!ck said "Don't worry about it".
Home > Message Board > Car Audio > Amplifiers > Archive through February 22, 2007 > SOUNDSTREAM AMP [ « Previous ] [ Next » ]
