Home > Message Board > Car Audio > Subwoofers > Archive through February 15, 2007 > Help Me Out
Author Thread: Help Me Out
Username: Loc_out
Santa Ana, Ca
Resonant Eng...
Post Number: 666
I just bought a Re XXX DVC 2ohm. Correct me if i'm wrong but i could wired it to 1ohm and 4 ohm right???
I wanted to use this amp cuz i already own it Audiobahn A1600V. This are the spec on ebay
RMS Power @ 4 Ohms: 800W @ 4 ohms
Bridged RMS Power @ 4 Ohms: 1,600W @ 2 ohms
http://cgi.ebay.com/AUDIOBAHN-A16000V-MONO-1600-WATT-AMPLIFIER-NEW-07-AMP_W0QQit emZ140085617663QQihZ004QQcategoryZ64571QQrdZ1QQcmdZViewItem
Am i going to be about to use the audiobahn amp??
Please help
Username: Th3pwn3r
Chicago, Illinois
U.S.A
Post Number: 1012
Yes you can either wire it in parallel for a 1 ohm load or you can wire in series for a 4 ohm load.
Username: Loc_out
Santa Ana, Ca
Resonant Eng...
Post Number: 667
But will i be able to use that audiobahn amp??
Username: Th3pwn3r
Chicago, Illinois
U.S.A
Post Number: 1016
You can use that amp but you won't be getting much power for that sub.Make sure you wire in series because I don't think that amp is 1 ohm stable.
Username: Rovin
1 12 Atomic ...
Post Number: 10703
NO ! rob ^^
his amp is NOT 1ohm stable http://www.audiobahn.com/Audiobahn06/pages/amps.html
so ur only choice is to wire it @ 4ohms like this Upload
i recently heard a xxx 15 on only 1000wrms & boy it hit real deep\hard.......
Username: Rovin
1 12 Atomic ...
Post Number: 10704
whoops had another thread opened & posted after u said so it seems - my bad ....
Username: Sinful_systems70
Post Number: 378
Yes 4 ohms because I don't think that amp is stable any lower than 4 ohms when bridged, and I hope you plan to run it bridged because even then you will be underpoweing that sub. JMO
Username: Loc_out
Santa Ana, Ca
Resonant Eng...
Post Number: 668
I dont think i can bridged that amp cuz it only has One + and One - speaker out let.
Username: Johnfiac
IL
Afghanistan,...
Post Number: 1394
Its a mono amp, no bridging involved LMAO ebay specs are so predictable
It does 800@4 ohm and 1600@2ohm, not 1 ohm stable. If you wanted more power outta the amp you ordered the wrong VC config for the sub... DVC4ohm woulda been a better choice.
Username: Loc_out
Santa Ana, Ca
Resonant Eng...
Post Number: 669
Nice time to start looking for a new amp. Will that sub be moving at 800Watts?
Can you guys name accouple of amps that are 1ohm stable. Budget is 300ish the lower the better.
Www.15inchwangers.com
FI Audio BTL
Post Number: 10321
look in to some hifonics if you don't want to spend too much money.
Username: Rovin
1 12 Atomic ...
Post Number: 10710
around that budget u have to go ebay & look @ some Hifonics Brutus amps ......
Username: Loc_out
Santa Ana, Ca
Resonant Eng...
Post Number: 670
Chad i believe you had an XXX right? If i only give it 1200 would i still be underpoweing it?
Would i hear a big difference 800@4ohm then 1200@1ohm?
Username: Adam_s
15 TC9 Hybrid, RE MT Softparts
Post Number: 649
1200 would get it moving pretty nice. There would be a difference from 800 to 1200. but if those numbers come from hifonics they are a little over rated so expect to get 1000-1100 @1 ohm.
Username: Loc_out
Santa Ana, Ca
Resonant Eng...
Post Number: 672
What other kind of amp should i look for if bump my budget to 400ish?
Username: Rovin
1 12 Atomic ...
Post Number: 10715
is that a 2oo5 or 2006 model XXX ?
either way IMO i'd use more than 1200wrms , @ least 1500wrms i would get , u could get get by with a 2000 Hif brutus if $$$ is tight ....
Username: Loc_out
Santa Ana, Ca
Resonant Eng...
Post Number: 678
Its a 2005XXX. If the audiobahn can move that sub i am going to save and get a good amp.
Username: Loc_out
Santa Ana, Ca
Resonant Eng...
Post Number: 680
So when i got home yesterday i wired the XXX to 4ohm. I used the audiobahn amp damn that sounded so clean and it was louder then my w6. Can’t wait to buy a bigger amp. }
Username: 54danny54
KY
More Wang Th...
Post Number: 3485
massive audio p1500.1
Home > Message Board > Car Audio > Subwoofers > Archive through February 15, 2007 > Help Me Out [ « Previous ] [ Next » ]
