Home > Message Board > Car Audio > Amplifiers > Archive through February 22, 2007 > Witch of these amps?
Author Thread: Witch of these amps?
Username: Mike_16
Burlington, Wisconsin
Us
Post Number: 216
would u guys use a kcker zx1000.1, kx1200.1, or a hifonics 1606 amp for 2 fi bl subs, im gonna be useing 2 of the amps, so witch ones would be best, i was thinking hifonics cuz teh price but it dosent even have the holes for holding the amp in place from moveing around so would any of those kicker amps work good with those subs? or would they iunderpower them? let me know plz
Username: Adddisorder
West palm, Florida
Post Number: 3193
kx1200.1 will give you the most power
Username: Mike_16
Us
Post Number: 217
ok so i will prolly get 2 of em then but i hope there good for the price, im sure they are there kicker lol. i like kciker allot.
Username: Ctmike
Ct.
Post Number: 3382
those amps are great. i've never heard of any kx1200.1 benching below 1400wrms, most are more.
Username: Mike_16
Us
Post Number: 218
dang so there wayy underatted? how come?
Username: Nyyfan13
Fi SSD
Post Number: 3530
yea most of them put out between 1400-1500...
Username: 04redmach1
Columbus, GA
Post Number: 344
Also, consider the Massive Audio P1500.1 for VERY good budget amps.
Kevin
Username: Mike_16
Us
Post Number: 224
so masive amps are good, where can u find them online at?
Username: Sinful_systems70
Post Number: 385
Depends on your budget but the 1200 is the better of the three.
"i was thinking hifonics cuz teh price but it dosent even have the holes for holding the amp in place from moveing around" ---- Hifonics does have tabs to mount the amp where they won't move around. Just to clear that up.
Username: Mike_16
Us
Post Number: 226
oh realy? well do they come with the amp?
Post Number: 394
Yep. youu have to screw them on.
Username: Mike_16
Us
Post Number: 227
alright well there not to much cheaper then the kicker 1200.1 on ebay there a lil cheaper so witch should i go for
Username: Ctmike
Ct.
Post Number: 3392
the kicker.
Username: Mike_16
Us
Post Number: 233
ok thanx , what ohm load do think it will be on with the 2 fi bl's 12 inch, with tose amps
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 4151
if you're going to use 2 amps, then they must be dual 2 ohm in order to run each amp at 1 ohm (kicker kx 1200.1)
Username: Mike_16
Us
Post Number: 235
alrigth so th esube have to be dual 2 ohm ok, but why would the amp be 1 ohm if the subs are 2 ohm is it cuZ there dual
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 4155
www.the12volt.com
hit the link woofer wiring
Username: Mike_16
Us
Post Number: 237
ok thanx
Home > Message Board > Car Audio > Amplifiers > Archive through February 22, 2007 > Witch of these amps? [ « Previous ] [ Next » ]
