Thread: (PAIR) 2007 KICKER 07 CVR124 CompVR 12" |
New member Username: Chadley01
West chicago
Post Number: 2 Registered: Feb-07
| Posted on Tuesday, February 13, 2007 - 08:32 am: |
Hey i just got these subs from ebay and im looking for a good but not that expencive amp to go along with it. could you help me out it would be great. Specifications: RMS Power: 400W Recommended Peak Power Handling: 800W Injection Molded Polymineral Cone with ISD (Inverted Structural Dome) Spring-Loaded Nickel Plated Terminals Double Stitched Surround Rear Cone Brace Optimized Polyfoam Ribbed Surround Radius High-Temp Polyimide Film Voice Coil Former Dual Ultra-Length Voice Coils Sleeved High-Power Tinsel Lead Wires New Enhanced BAM (Basket and Motor) Assembly Perimeter Venting in the BAM One-Piece Uniplate with Vented Hyper-Extended Blackened Pole Piece and Backplate Rec. Sealed Box Dims: 1.00 - 4.60 cu.ft. Rec. Ported Box Dims: 1.75 - 2.25 cu.ft. Free Air Usage: not recommended Sensitivity: 86.7 dB Frequency Response: 25-500 Hz Impedance: dual 4 ohms subwoofer wiring options Mounting Depth: 6-3/16" and they are Dual vc |
Bronze Member Username: Mmaudioconcepts
Murray,
KY
Post Number: 29 Registered: Jan-07
| Posted on Tuesday, February 13, 2007 - 11:23 am: |
Soundstream TRA800.2 Audiobahn A8002V |
Silver Member Username: Naledge503
Qnited States of FI Ca...
Post Number: 836 Registered: Jun-06
| Posted on Tuesday, February 13, 2007 - 12:02 pm: |
Both of those are good suggestions. Alot of people go with the audiobahn A8002V or A8002T, which are the same exact amp on the inside. The V is the newer version and have a voltage meter on the front. You could also look into the Hifonics Bxi 1206d. It claims 1200 watts rms but alot of people have benched these more around 1000 watts rms. So given that it is overrated and efficiency...You should see a around 900-1000 rms which would be nice on those subs. Dont worry they can handle the litte extra power. |
West chicago
Post Number: 7 Registered: Feb-07
| Posted on Tuesday, February 13, 2007 - 07:08 pm: |
witch one would be best? http://cgi.ebay.com/NEW-Audiobahn-A8002T-2-Channel-Amplifier-MOSFET-2-X-100_W0QQ itemZ220080568607QQihZ012QQcategoryZ38638QQssPageNameZWDVWQQrdZ1QQcmdZViewItem or http://cgi.ebay.com/A8002V-Audiobahn-800W-RMS-2-1-Ch-Intake-Amp-NEW-A8002T_W0QQi temZ220081797658QQihZ012QQcategoryZ48597QQssPageNameZWDVWQQrdZ1QQcmdZViewItem |
West chicago
Post Number: 9 Registered: Feb-07
| Posted on Tuesday, February 13, 2007 - 09:18 pm: |
if i were to get that how would i wire it? |
Platinum Member Username: Chaunb3400
Huntsville,
Alabama
U.S.
Post Number: 11440 Registered: Jul-05
| Posted on Wednesday, February 14, 2007 - 03:19 am: |
http://www.the12volt.com/caraudio/woofer_configurations.asp |
Bronze Member Username: Chadley01
West chicago
Post Number: 14 Registered: Feb-07
| Posted on Saturday, February 17, 2007 - 02:00 pm: |
how should i run the wire 2 or 4 ohm? |
