Home > Message Board > Car Audio > Amplifiers > Archive through February 22, 2007 > UREGENT!: i need help wiring!
Author Thread: UREGENT!: i need help wiring!
Username: Torn
Post Number: 15
i have a jl w6 dvc 6 ohm sub i need help on wiring of sub and wiring of amp. how would i wire the sub? i connected wires from pos to other side of pos and same thing with the negatives is this the correct way to do it? and also how would i wire the subs to a audiobahn a8002t?????? this is the first time owning a dvc sub and @ 6 ohms, i need answer quick!!! much appreciated.
Username: Sinful_systems70
Post Number: 351
Go here and scroll down for your answer.http://mobile.jlaudio.com/pdfs/8-12W6_BDS.pdf
Post Number: 355
Your welcome!
Username: Torn
Post Number: 16
nice i am still new about this ohm load thing for amps would i be able to run it 1 channel with this sub? and if i bridged it wouldnt there be too much power going to it? the amp is audiobahn a8002t
thanks!
Post Number: 358
the amp is
200 X 2 at 4 Ohms Stereo
400 x 2 at 2 Ohms Stereo
800 x 1 at 4 Ohms Mono
Sub handles 300 RMS and since you only have one, you will have to run it at 3 ohms because the amp will not go to 12 ohms.All info is on the page I posted before.
Username: Torn
Post Number: 17
is the 3 ohm load on that in 1 channel or bridged mode? and if i had another w6 would i be able to run both like that on the amp?
Post Number: 368
Its 3 ohms no matter weather bridged or not. Just so you know that amp is only stable at 4 ohms when bridged to 800 watts. The three ohm load is a parallel wiring of the DVCs. "and if i had another w6 would i be able to run both like that on the amp? Yes, but the ohms would then be a 1.5 ohm load if you mean to still run parallel. If you run the two subs in series than that will present a 6 ohm load. You will have to have three of these subs to get a 4 ohm load wired in series and a 1 ohm load wired in parallel. All this info came from the page I posted before. Take a look at it. Lots of pictures and easy to understand. Sorry, sick of typing.
Username: Torn
Post Number: 18
last question: the 300 rms of the dvc sub, is 300rms or 150rms in each voice coil or both voice coils? and is it safe to bridge the sub to that amp?
Home > Message Board > Car Audio > Amplifiers > Archive through February 22, 2007 > UREGENT!: i need help wiring! [ « Previous ] [ Next » ]
