Home > Message Board > Car Audio > Amplifiers > Archive through February 22, 2007 > Soundstream XXX-6500
Author Thread: Soundstream XXX-6500
Username: 420alldaylong
Post Number: 842
Soundstream XXX-6500D - Soundstream 1 Ch 6500 Watt Amplifier
Our Price: $1,679.99
Retail Price: $1,846.90 Save $166.91
Availability: In Stock
Features:
OUTPUT POWER: RMS/Chan @ 4 Ohms (Watts) 3400
RMS/Chan @ 2 Ohms (Watts) 4800
RMS 1 Ohms (Watts) 6500
T.H.D:. 1.0%
DAMPING FACTOR: >350
FREQUENCY RESPONSE(Hz): 5-250
INPUT SENSITIVITY: .5-10 Volts CONTINUOUSLY VARIABLE ELECTRONIC CROSSOVERS: LOW-PASS
SLOPE 18dB
S/N RATIO: >80dB
LOW-PASS FREQUENCY (HZ): 30-150
SUBSONIC FILTER SLOPE: 18dB
SUBWOOFER EQ @ 45Hz: 0-18dB
Soundstream XXX6500D Soundstream XXX 6500D 1Ch 6500 Watt Amplifier
Username: Oneracistguy
TWO EGG, FL
Post Number: 255
thats alot i got mine for 750 and it dosent do 6500 unless its at 16 volts
Post Number: 843
JB
Thats woofersetc price
What subs are you running on that amp.
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 4133
similar board of lanzar optidrive 4000d.
Username: 04redmach1
Columbus, GA
Post Number: 337
You may want to look at doing 2 Sundown Audio SAZ-1500D's strapped at 1 ohm. As lond as you have a strong 13 volt you can see 5000+ rms.
Kevin
Username: Naledge503
Qnited States of FI Ca...
Post Number: 838
Kevin, will the SAZ-1500D put out a solid 2k rms @ 1 ohm?
Columbus, GA
Post Number: 338
On the Sundown @ 1 ohm we have seen at 12.8 volts 1600-1800 strong. If you have a nice and strong 14 volt system you can see upwards of 2000 rms.
Kevin
PS: Strapped at 1 ohm with a steady 15 volts the amps gave 5700 rms on 1 test. Can't beat that on a 1500 rms rated amp :-)
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 4141
it should. Get IA 20.1
Post Number: 839
Thanks Kevin. Julio, Thats the amp I want, but its a little out of my budget right now. I just bought 2 Q's and an H/O alt. and need to get my box built. So for now I am gonna run the A3000DB but I plan on upgrading in the near future.
Columbus, GA
Post Number: 341
I will give you a small deal on a SAZ-1500D, shoot me an email.
lowhz01@yahoo.com
Kevin
TWO EGG, FL
Post Number: 256
u wont be happy with that amp as i found out it needs ALOT of power and i dout u have it i mean alot we had it on the quantum when we smoked it at around 4.5kw of clipped power we got rid of it actually and we are tryin summin new with marshalls box... its loud :-)
TWO EGG, FL
Post Number: 257
heres it off amp guts
1 x 1697W @ 4 ohm (13.5V)
1 x 1750W @ 4 ohm (14.4V)
1 x 2905W @ 2 ohm (13.5V)
1 x 3290W @ 2 ohm (14.4V)
1 x 4082W @ 1 ohm (13.5V)
1 x 4490W @ 1 ohm (14.4V)
but if u can get enough power like 4/0 wire ho alot and alot of battery power this will put out over 6500 watts if u can
Columbus, GA
Post Number: 343
Basically, get a semi charging system and your good to go :-)
Kevin
TWO EGG, FL
Post Number: 266
yea we put it in one of virgil williams cars that is a comp car made to burp he had a cadence daytona and when he hooked the ss amp up he said he never seen his voltage fall from 16 volts to 8 volts so quick
Home > Message Board > Car Audio > Amplifiers > Archive through February 22, 2007 > Soundstream XXX-6500 [ « Previous ] [ Next » ]
