Home > Message Board > Car Audio > Amplifiers > Archive through February 22, 2007 > Bought a hifonics brutus bxi1206d...n...
Author Thread: Bought a hifonics brutus bxi1206d...not pleased
Username: Quig
Pittsburgh, Pa
Us
Post Number: 273
Well before i had audibahn a8002t rated ta 800 rms... i have 2 rockford p3s in a 4.3 cubic slot ported box... i hit 119.5 db max on my spl meter... so i hook this brutus up its rated at 1200 rms, and of course thats gonna be true cuz its hifonics... well the bass is more clear... but i only hit 120 maybe a lil more at the dash... does this seem rite? i mean 140$ more for .5 db? does this seem rite please give me your comments.
Username: Quig
Pittsburgh, Pa
Us
Post Number: 276
oh and also... does anyone know waht the phase control does it goes form 0-180 degrees??? and also it has subsonic control, i kno thats for ported, but wat EXACTLY does it do.
Username: Van_man
Boston South, MA
Post Number: 1949
Phase set at 0 or 180. what ever makes the sub move out when it hits is the right phase, Unless your sub is inverted, then you want it reversed. Subsonic on. It cuts all useless freqs from playing.
And your amp choice. Still in the entry playground. Step up to the minors.
Username: Quig
Pittsburgh, Pa
Us
Post Number: 277
ok then wat do u recommend? wat setup will get me to 130 db on a spl meter?
Username: Quig
Pittsburgh, Pa
Us
Post Number: 278
ok then wat do u recommend? wat setup will get me to 130 db on a spl meter? my subs are not inverted, so i shuld have the phase to 180?
Username: Van_man
Boston South, MA
Post Number: 1953
Kicker L7 and a memphis St-161000D
Username: Van_man
Boston South, MA
Post Number: 1954
Kicker L7 and a memphis St-1000D
Username: Van_man
Boston South, MA
Post Number: 1955
It all depends. Look at the sub. Is it moving in or out when it hits? If it moves out, the switch is set. If it moves in, put it in the other position. Its like changeing the + and - speaker wire to the sub, with a switch, not by rewiring.
Username: Sinful_systems70
Post Number: 353
Pioneer Premier 3000Spl = inexpensive but good. I have two and very pleased. Over 140 SPL on Epic-160 meter under the dash in passenger side. Cheaper than L7 but just as good in my opinion. Both are good SPL. You will be pleased either way. JMO
Post Number: 354
Oh yeah, Even though neither is SQ sub, the Pioneer Premiers have a little better SQ than L7 in my opinion. JMO
Username: Logan__tille
[:-]15 Wangers Club[:-]
Premier Member
Post Number: 5774
your db meter prolly isnt the best..
Username: Quig
Pittsburgh, Pa
Us
Post Number: 285
the db meter says this on it spl1000, its made my schorche? idk you tell me lol first meter ive had.
Username: Quig
Pittsburgh, Pa
Us
Post Number: 286
Username: Rovin
1 12 Atomic ...
Post Number: 10694
good suggestion from Sinful
cheap subs yet they can do that no with the right install .......
Username: Adddisorder
West palm, Florida
Post Number: 3171
and you have a very crappy spl meter for one
and that hifo only puts out 80% of its rated power
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 4132
pioneer premier subs! very good FTW.
Post Number: 361
I hit 145 SPL to be exact playing Ludacris-"War with god" with subs & port facing back without back seat taken out. Back seat don't fold down. I plan to unbolt it see what I can do to get it to fold down.
Username: Quig
Pittsburgh, Pa
Us
Post Number: 287
cant find these subs anywehre, any links?
Username: Quig
Pittsburgh, Pa
Us
Post Number: 288
http://cgi.ebay.com/PIONEER-PREMIER-TS-W3004SPL-12-3000W-DVC-SUB-SUBWOOFER_W0QQi temZ280066508491QQihZ018QQcategoryZ48615QQrdZ1QQssPageNameZWD1VQQcmdZViewItem
is that them?
Post Number: 362
Yes, but they are 1000 watts rms. Not 1500 like it says. Just so you know.
Username: Quig
Pittsburgh, Pa
Us
Post Number: 289
hmm, 2 of them , with my amp, i wuld be underpowering them liek crazy? you think its worth it to get 2, or just get 1 18" or shuld i just buy another one of them amps 1 for each sub?
Username: Quig
Pittsburgh, Pa
Us
Post Number: 290
140 shipped good price for the premiers?
Username: Quig
Pittsburgh, Pa
Us
Post Number: 291
bump, so 140 shipped for the premiers a good price?
Username: N2audio
Lawrence, Ks
Post Number: 1194
are the p3's dvc 4's?
the 8002 needs a 4 ohm load - did you change your wiring [correctly] to get a 1 ohm load on the HF?
Username: Quig
Pittsburgh, Pa
Us
Post Number: 293
ya the dvc 4, ya i had them at 4 ohm and rewired them to 1 ohm...and upgraded to a 100 amp anl fuse
Username: Quig
Pittsburgh, Pa
Us
Post Number: 294
yes the yr dvc 4, i re wired them to 1 ohm. also upgrad3ed to 100 amp anl fuse
Username: Imalik
Jackson, New Jersey
Ocean
Post Number: 63
I have the same amp with 2 12 CVR and Im very happy with the amp.I know it will not do 1200 more like 1000 but the amp is a very good budget amp, Get someone who knows how to set the amp up you might change your mind.
Home > Message Board > Car Audio > Amplifiers > Archive through February 22, 2007 > Bought a hifonics brutus bxi1206d...n... [ « Previous ] [ Next » ]
