Thread: Hifonics |
New member Username: Robo07
Post Number: 1 Registered: Feb-07
| Posted on Monday, February 12, 2007 - 12:25 am: |
hey guys i'v been reading up on the hifonics amp and i plan on running to BXi1606D mono block hifonics amp...can anyone tell me if these are good amps, ok amps, or shitty amps thanks alot |
Silver Member Username: Hockeyknight
Post Number: 793 Registered: Apr-06
| Posted on Monday, February 12, 2007 - 12:33 am: |
hifonics are very good budget amps!!! but only expect to see about 80% of the rated rms |
Post Number: 3 Registered: Feb-07
| Posted on Monday, February 12, 2007 - 12:36 am: |
im gonna be running three L5 dual 4 ohm subs of two brutus amps how do u think that would do. |
Post Number: 4 Registered: Feb-07
| Posted on Monday, February 12, 2007 - 12:37 am: |
im gonna be running three L5 dual 4 ohm subs and wire it down to 2.65 omh of two brutus amps how do u think that would do. |
Bronze Member Username: Mmaudioconcepts
Murray,
KY
Post Number: 24 Registered: Jan-07
| Posted on Monday, February 12, 2007 - 12:39 am: |
if u must have a hifonics amp get one that is rated for more than what u need.if u need 800w get a 1000w amp.....like he said they over rate their amps..its not bad that they over rate them its just a different marketing technique.....two companies can test an amp at 1300w....1 will call it 1000w amp and the other will call it 1500w amp...people will always say the company that called it a 1000w amp is better |
Post Number: 5 Registered: Feb-07
| Posted on Monday, February 12, 2007 - 12:40 am: |
but would it hurt if i ran two of those amps with the three subs? |
Post Number: 6 Registered: Feb-07
| Posted on Monday, February 12, 2007 - 12:43 am: |
or would i be able to run those three L5's of a KICKER ZX1500.1 mono block amp. |
Post Number: 794 Registered: Apr-06
| Posted on Monday, February 12, 2007 - 12:45 am: |
that would be better |
Post Number: 7 Registered: Feb-07
| Posted on Monday, February 12, 2007 - 12:51 am: |
cuz i kno kicker under rates theri amps and its 1500 at 2 ohm's and the 2 L5's will be at2.65 or wut that comes out to be and im gonna have a 6 fard cap and o gauge wire do u think that amp will power those subs with out it cutting out or off??? |
Gold Member Username: Ctmike
Ct.
Post Number: 3346 Registered: Feb-06
| Posted on Monday, February 12, 2007 - 12:53 am: |
don't get a cap., waste of money. get a ho alt. |
Post Number: 8 Registered: Feb-07
| Posted on Monday, February 12, 2007 - 12:54 am: |
i just read up on those high end alt. and i plan on getting a 200 or 250 one. i would still like a cap. |
Post Number: 795 Registered: Apr-06
| Posted on Monday, February 12, 2007 - 11:42 am: |
well lets start over...u went from wanting a budget amp to a high end kicker and a h/o alt and a cap......u dont need the cap and u should get an h/o alt.......how bout u give us a budget and we could get a better feel af what u could get |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 4128 Registered: Dec-05
| Posted on Monday, February 12, 2007 - 12:44 pm: |
about the issue with 1000w rms amp that puts 1200w rms or 1500w rated amps put 1200w rms. Sinful, the thing is efficiency. You can try a hifonics bxi 1206d and try a kicker zx 750.1 and you'll see some differences. Even if they put the same watts and are rated differently. |
Silver Member Username: Northomaha
Post Number: 152 Registered: Mar-06
| Posted on Monday, February 12, 2007 - 03:55 pm: |
I have a hifonics bx1500d and it is a great amp. It is powering two treo tsx 15s and I have had nothing but good luck with it. It is also louder than most systems that I have heard. I like Hifonics for the money you get a lot of power. |
Bronze Member Username: Imalik
Jackson,
New Jersey
Ocean
Post Number: 64 Registered: May-06
| Posted on Friday, February 16, 2007 - 08:00 pm: |
I have a 1206d..It works for me...but if he is going to spend $500 get the XX-Zeus. Much better than th Brutus line http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=3395 |
